Open Source Hardware
Blog Free Chemistry, Heating and LoRa stuff [UK]
  • Author Author: shabaz
  • Date Created: 2 Sep 2019 11:16 PM Date Created
  • Views 4294 views
  • Likes 12 likes
  • Comments 23 comments
  • free stuff
shabaz
shabaz
2 Sep 2019
Hi, I've got some items unrequired, if you're in the UK and wish to have it, please let me know if you want "chemistry" or "LoRa" or "Heating" stuff and I'll post it for free.
All of this stuff is new and unused, and I hate to just throw it away since it's quite useful stuff.
Chemistry stuff:
6 x 100ml beakers (glass), a plastic funnel, 4 glass pipettes and some boxes of universal indicator (like Litmus paper).
LoRa stuff:
Two SX1276MB1MAS (European variant) LoRa transceiver boards, and two SMA antennas that I think are for the 868MHz band (the boards are dual-band, they have 433MHz capability too with the correct antenna). They're for mbed boards, (might fit Arduino but I don't know), but could easily be connected using jumper wires to any microcontroller board or Pi for instance.
Heating stuff:
Two Quartz Halogen tubes (277mm long, from Ceramicx, 240V, 1kW each, plus holders with aluminium reflectors and a few miscellaneous things like ceramic screw blocks. I got these with the intent of making a reflow oven, but that never happened.
  • Problemchild
    Problemchild over 6 years ago in reply to balearicdynamics
    True but really you need a matched pair initially it means you don't need two sets of code to set up the "pair"
  • Problemchild
    This collection sounds like you could use it for a project or experiment for the Nephews!!
    balearicdynamics over 6 years ago in reply to Problemchild
    Just to be impartial, if you get one for free maybe worth you will buy the other, as you spend half. Or not?
  • Problemchild
    Make sure you give the LoRa boards in at least pairs Shabaz otherwise they will not be able to talk to anything ...At least in terms of during testing of their project!
    JA
  • BigG
    BigG over 6 years ago
    Looks like the early birds have bagged the LoRaWorms... image
