Open Source Hardware
Forum element14 PCB service, get boards made in a day
  • Replies 11 replies
  • Subscribers 329 subscribers
  • Views 1548 views
  • fabrication
  • maker
  • pcb
  • Design
  • Technology
  • fab
  • service
  • opensource
Catwell over 15 years ago
Did you read about the new element14 PCB service? How does 1-2 day turn around on prototypes sound? Sounds about right to me.
See more at element14.com/pcbservices
Cabe
  • Kilohercas
    Kilohercas over 12 years ago in reply to e14 Contributor +1
    I always make my pcb in OHS park, it will give 3 copies, 2 layer with gold finish at only 5$/inch^2 ( if we consider that it will give three copies, cost is just 1.66$/inch2 ) and free shipping to. Only…
  • R_Phoenix
    R_Phoenix over 15 years ago
    I like the turn around time, but the cost is almost 3 times that of my current PCB service.
    michaelkellett over 15 years ago in reply to R_Phoenix
    In the UK I think that www.pcbtrain.com (Newbury Electronics) looks a better bet.
    Those prices seem crazy expensive compared to UK services.
    I thought pcbtrain was quite expensive, but they are much cheaper than pentalogix fast turn around.
    Pentalogix off-shore service appears to be more than 2x PCBcart prices.
    I don't understand what I am missing but this seems so expensive, I must be missing something because it doesn't stack up.
  • R_Phoenix
    R_Phoenix over 15 years ago in reply to e14 Contributor
    I think the prices are so high because of the fast turn around. The service I use, Pad2Pad gets more costly as the turn around time decreases, but still a bit cheaper.
  • Catwell
    Catwell over 15 years ago in reply to R_Phoenix
    Fast turn around is always a bit more expensive. Boards from element14 are going to be high quality.
    And the real benefit is for CADSoft Eagle users, with one click to PCB fabrication. A complete integrated experience is worth a little more.
    C
    e14 Contributor over 15 years ago in reply to Catwell
    A lot of PCB manufacturers take Eagle '.brd' files. I accept clicking a button inside Eagle is easier than emailing a single file to a company. IMHO the difference between those two is utterly trivial compared to using Eagle to create a viable PCB.
    I am sure Farnell will get business from their acquisition of Eagle, but this seems to me to be much less valuable compared to the ability to get a part numbered Bill-Of-Material.
    So, what layers are used for silk screen? It isn't mentioned, and I don't want to spend $200 to find out.
    Also, what could I change to make the board cheaper? The advantage of e.g. PCBtrain is I can see what difference choices make to production costs.
  • R_Phoenix
    R_Phoenix over 15 years ago in reply to Catwell
    Here is a direct comparison,
    Board Size, 4x3
    Silkscreen Top side only
    2 layers
    Sloder mask both sides
    Element14 Price Quote
    Lead Times in Business Days. Unit Prices in USD
    Qty1 Day2 Days4 Days7 Days
    4$85.20 ea$71.00 ea
    10$40.44 ea$38.08 ea$36.06 ea$33.03 ea
    20$25.20 ea$23.73 ea$22.47 ea$20.58 ea
    100$10.80 ea$10.17 ea$9.63 ea$8.82 ea
    Pad2Pad quote
    Qty11 Days10 Days8 Days6 Days
    4-$32.63 ea$53.81 ea$55.94 ea
    10-$17.72 ea$21.45 ea$25.17 ea
    20$11.22 ea$11.65 ea$14.45 ea$16.78 ea
    100$3.43 ea$4.57 ea$5.41 ea$6.25 ea
    So unless you need the board the next day, it is a big savings.
    These are top quality boards and I have never had an issue with them.
    I'm not trying to dis-respect Element14, but I have always thought their prices are a bit high (and Newark).
    e14 Contributor over 14 years ago in reply to R_Phoenix
    Forget about everything just look at http://www.pcbprice.com/compare/europe
    AWESOME image
    michaelkellett over 14 years ago in reply to e14 Contributor
    It's a nice idea but it need some serious work - if you set it up to look for a board on 10 working days delivery it ignores suppliers who offer a price for 5 day delivery even if that was lower than the price for 10 from a supplier it did find. They need to improve the search engine so that it looks for the best deal with some fuzziness in delivery otherwise you can (on my test case) end up with the best offer listed being twice the price you need to pay !
    Michael Kellett
    That is awfuly weak.
    I tried 10off, 100mm x 100mm with slow, 25day delivery, and it was 5x more than several web suppliers, and ignored (at least) four suppliers who could deliver in less time for less money.
    It's notion of matching is so crude that it is actually misleading.
    Needs lots more work.
