Open Source Hardware
Forum membrane switch graphic overlays
  • Subscribers 327 subscribers
  • Views 1033 views
Hello I hope this question isn't being posted in the wrong area but I am trying to locate a process for making custom membrane switch graphic overlays at home.  I have looked online and there are many site that will make them for you at rather high cost but for a simple protoype i would like to make my own.  Any help or information would be greatly appreciated.
Thank you
Jason
  • R_Phoenix
    R_Phoenix over 14 years ago
    Do you have an image you can post showing what type of membrane you are looking for?
    e14 Contributor over 14 years ago in reply to R_Phoenix
    http://www.rspinc.com/product-gallery-1-1.htm
    something like this but i would like to change what is on the context buttons the the right of the keypad.  i am using it on an industrial cnc machine and i have had to replace the standard plastic capped button three times now becasue of oil, dirt and coolant getting into them.  I want a completely sealed front and I also have a few other projects I could use them on.
    Thanks for the help
  • R_Phoenix
    R_Phoenix over 14 years ago in reply to e14 Contributor
    Ah, I was thinking more along the line of a clear rubber type membran that covered the mechanical switches. For that you can use some Smooth-On .
    I'm not sure how these types could be made. Interesting.....
    Hi Jason!
    I have used membrane pads similar to this before.
    http://uk.rs-online.com/web/p/keypads/0507497/
    They are a sealed transparent front panel with pockets for slide-in paper legends.
    The flat ribon is fed through a small slot in the front panel and the keypad is self-adhesive so it sticks on to the panel.
    Hope this helps! :-)
