Open Source Hardware
Forum Install linux-headers and compile your driver on pcDuino
  • Subscribers 326 subscribers
  • Views 439 views
  • openhardware
  • pcduino
alvin_jin
alvin_jin over 13 years ago
You can get pcDuino kernel source code from https://github.com/pcduino/kernel, and follow the guide http://www.pcduino.com/?p=957 to build your own kernel.
However, sometimes people do not want to build the whole kernel, but only some drivers, and they do not want to use another machine to build a simple driver.
This guide will show  you how to build your drivers on pcDuino.
1) install pcduino-linux-headers-3.4.29+
Code:
$ sudo apt-get update && sudo apt-get install pcduino-linux-headers-3.4.29+
Note:
You need to update your system to 2013-05-31 version to do this.
2) make a new directory and write a test driver
Code:
$ mkdir hello && cd hello && cat > hello.c << EOF
#include <linux/init.h>
#include <linux/module.h>
static int pcduino_hello_init(void)
printk("Hello, pcDuino\n");
return 0;
static void pcduino_hello_exit(void)
printk("Bye, pcDuino\n");
MODULE_LICENSE("GPL");
MODULE_AUTHOR("pcDuino Team");
module_init(pcduino_hello_init);
module_exit(pcduino_hello_exit);
EOF
b) Create a  Makefile
Code:
$ cat > Makefile << EOF
obj-m = hello.o
EOF
3) Compile and run test driver
a) compile
Code:
$ make M=`pwd` -C /usr/src/linux-headers-3.4.29+
b) load driver
Code:
$ sudo insmod hello.ko
you can see the debug message by:
Code:
$ sudo dmesg | tail -n 1
[ 1414.020000] Hello, pcDuino
c) Unload driver
Code:
$ sudo rmmod hello.ko
Code:
[ 1486.290000] Bye, pcDuino
