Open Source Hardware
Forum openFrameworks runs on pcDuino
  • Subscribers 326 subscribers
  • Views 522 views
  • pcduino
alvin_jin
alvin_jin over 13 years ago
digitalhack posted a blog about getting openFrameworks to run on pcDuino.
http://digitalhacksblog.blogspot.com/2013/06/openframeworks-pcduino.html
Setup the pcDuino to use Mali Framebuffer
git clone https://github.com/digitalhack/sunxi-mali.git
cd sunxi-mali
git submodule init
git submodule update
make config VERSION=r3p0 ABI=armhf EGL_TYPE=framebuffer
make
make install
make test
stop lightdm
./test/test
At this point you should see something that looks like this
MaliTestTraiangle
Setup openFrameworks
git clone https://github.com/digitalhack/RaspberryPi-openFrameworks.git
cd RaspberryPi-openFrameWorks
cd scripts
sudo install_dependancies.sh
sudo install_codecs.sh
sudo install_poco_libraries.sh
Compile and run the pcDuino Hello World Program
cd ../apps/devApps/pcDuino_hello_world_gles2
make PLATFORM_VARIANT=puduino
sudo ./bin/pcDuino_hello_world_gles2
At this point you should see a spinning pcDuino board on a yellow background.
  • fustini
    fustini over 13 years ago
    Hi - I've been curious about the pcDuino so interesting to see your posts.  However, you might want to consider creating blog posts instead of discussion posts.  I think that content type would suit what you are posting better.
    The Open Source Hardware blog is at:
    http://www.element14.com/community/groups/open-source-hardware?view=blog
    This 'Create new blog post' link should take you to the right place:
    http://www.element14.com/community/groups/blogs-create-post!default.jspa?blog=1394
    BTW, did you get your pcDuino from SparkFun?  I saw they sell them.
    Cheers,
    Drew
