Open Source Hardware
Forum Raspberry Pi or Beagle Board!!??
  • Replies 22 replies
  • Subscribers 330 subscribers
  • Views 3863 views
  • beagle_boad
  • bb_black
I want to know which is better Raspberry Pi or Beagle Board?
  • johnbeetem
    johnbeetem over 13 years ago +2
    There's going to be an Open Source Hardware Panel Discussion at the upcoming DesignWest show in San Jose, California starring Jason Kridner (BeagleBoards) and Gert Van Loo (Raspberry Pi / Gertboard). I…
  • jkridner
    jkridner over 13 years ago in reply to michaelkellett +2
    Note that the BeagleBone has 2 200MHz 32-bit RISC microcontrollers (programmable real-time units or PRUs) that can be programmed with an open source assembler to perform real-time tasks. The typical approach…
    DAB over 14 years ago +1
    For price/performance, you should take a look at the TI MSP430 line. The Launchpad only costs 4.30 USD and gives you a sixteen bit device. If you go read my Blogs on the MSP430F5438IPZR MSP430F5438IPZR…
    0 michaelkellett over 14 years ago
    What is your application ?
    Michael Kellett
    0 e14 Contributor over 14 years ago in reply to michaelkellett
    I am starting. Apart from Price, what are the characteristic differences? use for robotics and real-time embedded application.
    0 michaelkellett over 14 years ago in reply to e14 Contributor
    I don't think I would use either for what I would call a real-time embedded application but the defintion of real-time is very vague.
    from Wiki: systems that are subject to a "real-time constraint"— e.g. operational deadlines from event to system response
    But on that basis almost everything is  a real time system.
    So the Beagle and RPi are OK for deadlines in the order of 10s of mS, less with some hard work, but they don't (normally) use a real time OS.
    But you should do your own research - download the data for both boards - compare them with each other and your specification.
    No one can help you unless you describe your project in a lot more detail.
    Michael Kellett
  • robotonics
    0 robotonics over 14 years ago
    As an Engineer I would choose the Beagle Board...especially with the fiasco surrounding Raspberry Pi at the moment.
    0 DAB over 14 years ago
    If you go read my Blogs on the MSP430F5438IPZRMSP430F5438IPZR, you will see that the MSP430 has a very robust suite of real time options that would be ideal for robotics or any other real time processes.
    Just a thought,
  • Nate1616
    0 Nate1616 over 14 years ago
    I agree with the posts above in that we would need to know your intended application a little more.   But if you are set in using one of the 2 then I would go with the beagle board.  I'm a fan of the raspberry pi but think beagle board is a better solution all around.  Like DAB said for the price and robustness the msp430 is the best solution.  Just me thought though.
  • ssilberhorn
    0 ssilberhorn over 14 years ago
    Here is some more information on the BeagleBoneBeagleBone to help with your decision...
    Also a good discussion here on the Pi vs. BeagleBone...  http://www.element14.com/community/message/52904#52904/l/re-combining-beaglebone-and-raspberry-pi
    http://beagle.s3.amazonaws.com/graphics/beaglebone/beaglebone-in-hand.JPG
    What is the BeagleBoneBeagleBone capable of doing?
    Watch the vidoes, find design files, view the addon boards and simply learn more here...
    That's absolutely not the case.
    Almost nothing is a real time system.
    real-time is about meeting the deadline or missing the deadline as in event occurs at time X. Deadline is at X + 30ms.
    In case of hard real-time if the deadline is missed somebody might get hurt or die (airplane, car, robots etc.).
    In case of soft real-time if the deadline is missed it's inconvenient (video streaming, voice over ip etc.).
  • fustini
    0 fustini over 14 years ago in reply to ssilberhorn
    Given this the Open Source Hardware group, it's worth noting that the BeagleBone is Open Source Hardware.  The design files are available here: http://beagleboard.org/hardware/design/
    Unfortunately, at this time, the Raspberry Pi can not be considered Open Source Hardware.  The schematic has been released, but the board layout has not yet been released.  The Raspberry Pi Foundation has commented that they would like to release it at some point in the future.
  • jealderson1
    0 jealderson1 over 14 years ago
    If you're interested in real-time embedded & robotics applications - what about a TI EvalbotTI Evalbot? Might be a good place to start because you can download the Micrium pdf book for free which takes you through using an RTOS from the beginning.
    Has anyone used one of these (or any other stellaris dev kits) - any opinions?
