Open Source Hardware
Forum Beginner Advice (which board to trigger light on email)
  • Replies 13 replies
  • Subscribers 328 subscribers
  • Views 2647 views
I am planning on building a device that will trigger a Red Siren light when there are emails in a particular inbox.
I'd like to have the device check this email account via IMAP once every minute, and if there are emails in the inbox the light will be triggered.
I have done some initial googling and the closest project I could find is this one: http://www.instructables.com/id/Internet-Controlled-Desk-Lamp/?ALLSTEPS
This lamp is triggered via an Arduino when someone clicks a ON/OFF link on a web page.  At this point I am thinking it wouldn't be too much trouble to use this existing code and create a separate script that will check the email account and trigger a GET request to the ON link until the inbox is cleared and on a subseqent check of the email account will trigger the OFF link.
Unless there are any other suggestions on a better board (if not the Arduino) or method of implementing this?
Thanks in advance for any/all suggestions,
-BassKozz
  • bprewit
    bprewit over 13 years ago +1 verified
    Well, regardless of the what's and why's .. this: http://learn.adafruit.com/raspberry-pi-e-mail-notifier-using-leds might be a starting point. You'll have to figure out on your own how to tell if there…
  • jason721
    0 jason721 over 13 years ago in reply to e14 Contributor
    Hi Bass,
    I have been trying to replicate the problem and have had no luck. I am going to send you an email to get some additional info.
    Thanks for your help!
    Jason G.
    0 e14 Contributor over 13 years ago in reply to jason721
    the refresh triggered the buttons to display, I should be all set now, Thanks !
  • jason721
    Glad that worked. If you have any other problems in the future you can let us know by going to the Feedback & Support section and click on the Get Help Now Button. Easiest way I've found to get to Feedback & Support is the link at the very bottom.
    Jason G.
