Open Source Hardware
Forum Lasers?
  • Replies 24 replies
  • Answers 2 answers
  • Subscribers 330 subscribers
  • Views 4344 views
Lasers?
bradnorwood
bradnorwood over 11 years ago
Is anyone in this group familiar with lasers?
    DAB over 11 years ago +2
    I have worked with lasers for over forty years, what is your question? DAB
  • Kilohercas
    Kilohercas over 11 years ago in reply to bradnorwood +2 suggested
    Maybe you are talking about shutter. Basically you have fs laser that acts as shutter, and you have some material, that you shine light into. Ultrafast pulse changes properties of sample ( like Kerr effect…
  • Kilohercas
    Kilohercas over 11 years ago in reply to bradnorwood +2 verified
    it acts as On/Off switch by using Kerr effect. basically you will create shutter with ultrashort impulse, and you can "chop" other light source with it, aka shutter http://www.photonics.com/Article.aspx…
  • Kilohercas
    0 Kilohercas over 11 years ago in reply to bradnorwood
    you should look for Pockels cell, or Faraday rotator, you could control it by voltage/current by using polarized light and polarizer. This is best way to control light from laser. But it is controlled by electricity, not by light, so i don't know will fit your purpose
  • bradnorwood
    0 bradnorwood over 11 years ago in reply to Kilohercas
    All this is excellent knowledge! Thx for your time, I will research this more.
    0 DAB over 11 years ago in reply to bradnorwood
    If you are asking if one laser beam can interfere with the propagation of another laser beam, I do not think it is possible.
    First, the photon stream is very small and the mass of one photon is hard to use as a deflector for another photon.
    I am curious as to your intended application.
  • bradnorwood
    0 bradnorwood over 11 years ago in reply to DAB
    For 3D printing from liquids and powders to a 3D monitor for visuals...
  • D_Hersey
    0 D_Hersey over 11 years ago
    I heard of a scheme where they had like an aquarium full of a clear liquid monomer or dimer that would polymerize only if it was simultaneously exposed to both red and blue light.  The would scan it from two axes. . .
    OK, I believe most of them use pulsed lasers to control exposure time.
    If you use a CW laser, then you can use a simple shutter or deflector mirror to control the beam.
    I agree that using a laser to sinter powders to make metal objects is intriguing.  I have not been keeping up with the technology, but I know there are a number of pulsed laser with specific wavelengths that make this process easier.
    I am currently researching a new way to view individual atoms and how they bind physically, chemically and biologically via photon transfer.  One of my goals is to find specific frequencies that facilitate the bonding process with minimal energy needs.
    Time will tell.
  • bradnorwood
    That's interesting, I like the idea of controlling atoms with lasers too. The idea is to change the charge of the photons to alter them. I really like this.
  • michaelwylie
    0 michaelwylie over 11 years ago in reply to bradnorwood
    Like SLA printing?
  • D_Hersey
    0 D_Hersey over 11 years ago in reply to michaelwylie
    Supposed to be faster because it doesn't have to go layer-by-layer.  SLA uses UV to polymerize, this needs simultaneous red + blue.  I'm guessing that the material is expensive.
  • michaelwylie
    0 michaelwylie over 11 years ago in reply to D_Hersey
    Doesn't the peachy printer use a laser to print? Is this the idea you want to recreate Brad?
