Open Source Hardware
Forum Lasers?
  • Replies 24 replies
  • Answers 2 answers
  • Subscribers 330 subscribers
  • Views 4317 views
Lasers?
bradnorwood
bradnorwood over 11 years ago
Is anyone in this group familiar with lasers?
    DAB over 11 years ago +2
    I have worked with lasers for over forty years, what is your question? DAB
  • Kilohercas
    Kilohercas over 11 years ago in reply to bradnorwood +2 suggested
    Maybe you are talking about shutter. Basically you have fs laser that acts as shutter, and you have some material, that you shine light into. Ultrafast pulse changes properties of sample ( like Kerr effect…
  • Kilohercas
    Kilohercas over 11 years ago in reply to bradnorwood +2 verified
    it acts as On/Off switch by using Kerr effect. basically you will create shutter with ultrashort impulse, and you can "chop" other light source with it, aka shutter http://www.photonics.com/Article.aspx…
  • kas.lewis
    0 kas.lewis over 11 years ago
    Can you be more specific as to what you are looking for ?
    0 DAB over 11 years ago
  • Kilohercas
    0 Kilohercas over 11 years ago in reply to DAB
    i also work with best lasers out there, and your question should narrow
  • bradnorwood
    0 bradnorwood over 11 years ago in reply to DAB
    Hi DAB, I'm looking for a type of laser that can intersect with another laser to interfere or stop the propagation of the lasers. Is there any way of doing this?
  • Kilohercas
    0 Kilohercas over 11 years ago in reply to bradnorwood
    Maybe you are talking about shutter. Basically you have fs laser that acts as shutter, and you have some material, that you shine light into. Ultrafast pulse changes properties of sample ( like Kerr effect) , and you pass light only at that "two wave interaction" point
  • bradnorwood
    0 bradnorwood over 11 years ago in reply to Kilohercas
    How does this work? Will it cause the laser to send out a chopped beam? Can the laser be adjusted by power to shorten the beams distance?
  • Kilohercas
    http://www.photonics.com/Article.aspx?AID=41617
  • bradnorwood
    Thx, I'll read up on it soon.
  • Kilohercas
    it is only for fs lasers, like Ti:Sa or Yb:KGW, since you need lot of intensity to get Kerr effect into action, it's not about average power, it's about peak intensity
  • bradnorwood
    I'm looking for a way to control light in free space. In 3D, either lasers or actual light without physical points or objects to reflect it off of.
