Open Source Hardware
Forum We need more open source tooling for the workbench - Benchtop Vacuum Tweezers ?
  • Subscribers 326 subscribers
  • Views 11 views
  • Users 1 member is here
  • open source
  • open source hardware
  • vacuum tweezers
stanto
stanto 54 minutes ago
Happened upon this fun little build: https://github.com/ARENARobotics/MiniPic
Taken from the repo:
Open-source vacuum tweezers built for repairability. Engineered for SMD soldering and precision rework, with a robust design adaptable to any application requiring controlled suction and handling of small parts.
Features
  • Two operating modes: foot pedal starts or stops the vacuum motor
  • Solenoid valve for instant component release
  • Heat-resistant pen rated up to 160°C
  • Full set of precision needles and suction cups for all sizes of SMD components
  • Handles components down to 0201 (0.6 x 0.3mm) and up to 100g
  • Flexible silicone vacuum tubing
  • MX hot-swap mechanical switch in the foot pedal
  • Slip-resistant rubber feet
  • Inline filter to protect the vacuum motor
  • LED status indicator for vacuum engagement
You can buy the kit for $135 assembled, by a group/company that create combat robots (not sure if it's combat as in battlebots or combat as in war).
This might work well as part of a pick and place machine? Bit more automation to it. At least it should prevent the parts going pyoing from actual tweezers.
