Open Source Hardware
Forum regarding current controlled device.
  • Subscribers 326 subscribers
  • Views 540 views
msrinivasan19995
msrinivasan19995 over 9 years ago
I'm using peltier for heating a device from 90'c to 60'c ,vice versa for n cycles. I wanted to know how to control the current passing into the peltier. The peltier maximum current rating is 8A, i want to switch it between 6-8 A to get the desired value of temperature. Can anybody suggest a circuit to control the current flowing into the peltier. Suggestions are welcome.
  • koudelad
    koudelad over 9 years ago
    Have a look at this older discussion: https://www.element14.com/community/message/134015/l/re-digital-currentvoltage-control#134015
    I would suggest using a PWM capable microcontroller and a FET that can handle that amount of load. Microcontroller is preferred if you need some more complex algorithm / controller and or some interface to control the process manually on the go.
    David
