Open Source Hardware
Documents Sparkfun lummenati 3x3
  • Author Author: rmiltenberger
  • Date Created: 13 Mar 2018 1:20 PM Date Created
  • Last Updated Last Updated: 6 Oct 2021 9:31 PM
  • Views 1267 views
hi fveryone
  I got 5 SOARKFUN LUMMENATI 3x3  LED boards for free, but I can't find any information on coding them, ir what to code them on.
  I would like to daisy chain them around a Top hat, and encode several different chase patterba,,
  I have already wired them together do/ di
co/ic as well as voltage and ground...
  i am hoping someone out there can help me with the code to get this project running
tjanks in advance
I love ELEMENT14,,,,
BOB M
    shabaz over 8 years ago +4
    Hi Bob, Wiring and code examples are here: https://learn.sparkfun.com/tutorials/lumenati-hookup-guide?_ga=2.105904067.1534843765.1520948181-898059443.1500593718
    shabaz over 8 years ago in reply to rmiltenberger +4
    If you require this to work with an Arduino board, you can use the same code as on that page - that SAMD21 board is an Arduino board. You may need to tweak the pin names to suit your specific board (and…
    Hi Bob,
    Hi Bob,
  • rmiltenberger
    rmiltenberger over 8 years ago in reply to shabaz
    shabaz,
      I have the boards wired, what I need is coding help
    snd what to code them with,, as far as I can see there are no audrino libraries to code this chips, and appatently, you need a certain micro controller,,
    asmd12
    If you require this to work with an Arduino board, you can use the same code as on that page - that SAMD21 board is an Arduino board. You may need to tweak the pin names to suit your specific board (and google for 'fastled Arduino' because that is the name of the library you'll be using), but the code is there.
