Passive Components
Passive Components
Forum 1W-5W Resistor needed...
Join Passive Components to participate - click to join for free!
  • Subscribers 110 subscribers
  • Views 690 views
  • passive
  • resistors
Hi
I am looking for 1W-5W resistor 82k 5% or 5% 47k-resistant high-energy states Transitional. The best solution would be for me to wire wound resistor, but I have big problems with finding those values of resistance in the implementation of this technology and dimensions not exceeding A = 4mm B = 25mm (for the baseline case przymując Axial type).
  • ASano
    ASano over 16 years ago
    Hi
    On the website of Newak or Farnell is present a resistor.
    http://www.newark.com/vishay-dale/cw01082k00jb12/resistor-wirewound-82kohm-10w-5/dp/03F5042?Ntt=CW01082K00JB12
    http://it.farnell.com/vishay-dale/cw01082k00jb12/resistor-wirewound-82kohm-10w-5/dp/1333203
  • hargreaves
    hargreaves over 16 years ago
    Hi Jacob.
    When you say high energy, what do you mean. Do you mean pulse input. The reason I ask is could you use this part?
    http://uk.farnell.com/welwyn/mfp2-82k-ji/resistor-2w-5-82k/dp/1565492
    This can take beyond 500V so may cope with some pulse conditions. You need to be sure though, because high pulses will take it out of tolerance.
