Passive Components
Passive Components
Forum Help identifying and procuring replacement cap.
Join Passive Components to participate - click to join for free!
  • Subscribers 110 subscribers
  • Views 1303 views
Hi guys, struggling to find a replacement cap and was hoping someone could point me in the right direction. Capacitor is from Samsung monitor but ive never had to replace one like this one.
    jw0752 over 11 years ago +1
    Hi Hinnan, This is a small super capacitor probably used to retain memory. These will not look exactly the same but are equivalents. http://www.newark.com/webapp/wcs/stores/servlet/Search?catalogId=15003&langId…
    jw0752 over 11 years ago in reply to e14 Contributor +1
    If you have any doubts take some measurements and check out the data sheet. http://www.farnell.com/datasheets/1754672.pdf If you have room you could probably move it a bit too and extend the leads. I doubt…
    0 jw0752 over 11 years ago
    Hi Hinnan,
    http://www.newark.com/webapp/wcs/stores/servlet/Search?catalogId=15003&langId=-1&storeId=10194&gs=true&st=0.1F%205.5V
    0 e14 Contributor over 11 years ago in reply to jw0752
    Thank you John, so as long as they fit and are 5.5v / 0.1f they should work fine?
    For example this one should fit ok
    http://www.newark.com/kemet/fg0h104zf/cap-super-0-1f-5-5v-rad/dp/18X4845
    0 jw0752 over 11 years ago in reply to e14 Contributor
    If you have room you could probably move it a bit too and extend the leads. I doubt if there would be any problem in this application.
