Passive Components
Passive Components
Forum I am looking for a cross reference for a 10 K ohm Pot
Join Passive Components to participate - click to join for free!
  • Answers 2 answers
  • Subscribers 110 subscribers
  • Views 1765 views
  • cross_ref
  • rotary_pot
robblain
robblain over 11 years ago
The part is marked with the following on the back "106-10124MT 10K 0041" and on the side "213-50701-01 ECL A" and below that "W/O47446  0130".
I am looking for a replacement but i am having trouble finding a cross reference.
Any suggestions?
    jw0752 over 11 years ago in reply to robblain +1 suggested
    Hi Robert, You may have to find a substitute as most of the controls used on equipment are only available from the Original Equipment Manufacturer if you want an exact replacement. You will need to determine…
    0 dougw over 11 years ago
    Can you supply a picture?
  • robblain
    0 robblain over 11 years ago in reply to dougw
    I will upload some.
  • robblain
    0 robblain over 11 years ago in reply to robblain
    @@@@@@@@@@@@@@@@imageimageimageimage
    0 jw0752 over 11 years ago in reply to robblain
    Hi Robert,
    You may have to find a substitute as most of the controls used on equipment are only available from the Original Equipment Manufacturer if you want an exact replacement. You will need to determine if the control is linear or has an Audio or Exponential taper. Turn the control to the half way point and measure the resistance from the center to one of the side contacts. If it is about 5K then chances are that it is a Linear taper. Beyond getting the correct taper all the 10K pots will substitute for one another. I have in the past bought them with long shafts and used the drehmel to cut them to the needed size and shape. I looked through my grave yard but did not see one in the 10K range similar to the one you pictured. Here is one from NTE Electronics:
    http://www.ntepartsdirect.com/ENG/PRODUCT/501-0039
  • robblain
    Thanks John, i will try the resource that you provided.
