Passive Components
Passive Components
Forum My 4 servos are all turning simultaneously with one Potentiometer Why??? Please see my code...thanks
Join Passive Components to participate - click to join for free!
  • Subscribers 109 subscribers
  • Views 891 views
Hi everyone,
As the title states: "My 4 servos are all turning simultaneously with one Potentiometer"  That is not the way the project is suppose to work.
Each servo is to work independently of the other 3, with its own potentiometer.
I don't know what is happening..but here is the code, I am hoping someone can help me with this.
CODE:
#include <Servo.h>
Servo myservo0;  // create servo object to control a servo
Servo myservo1;  // i added
Servo myservo2;  // i added
Servo myservo3;  // i added
int potpin0 = 0;  // analog pin used to connect the potentiometer (i added the zero to the potpin before the equal sign)
int val0;    // variable to read the value from the analog pin
int potpin1 = 1;  // i added
int val1;         // i added
int potpin2 = 2;  // i added
int val2;         // i added
int potpin3 = 3;  //  i added
int val3;         //  i added
void setup()
  myservo0.attach(3);  // attaches the servo on pin 9 to the servo object
  myservo1.attach(5);  // i added
  myservo2.attach(6);  // i added
  myservo3.attach(9);  // i added
void loop()
  val0 = analogRead(potpin0);            // reads the value of the potentiometer (value between 0 and 1023)
  val0 = map(val0, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  myservo0.write(val0);                  // sets the servo position according to the scaled value
  delay(15);                             // waits for the servo to get there
  val1 = analogRead(potpin1);            // i added
  val1 = map(val1, 0, 1023, 0, 179);     // i added
  myservo1.write(val1);                  // i added
  delay(15);
  val2 = analogRead(potpin2);            // i added
  val2 = map(val2, 0, 1023, 0, 179);     // i added
  myservo2.write(val2);                  // i added
  delay(15);
  val3 = analogRead(potpin3);            // i added
  val3 = map(val3, 0, 1023, 0, 179);     // i added
  myservo3.write(val3);                  // i added
  delay(15);
Thank you in advance for any and all assistance I may receive.
Anna
  • element14jamie
    element14jamie over 13 years ago in reply to e14 Contributor +1
    Thank you coder27 it is appreciated. Jamie
  • element14jamie
    0 element14jamie over 13 years ago
    Hello Annasta,
    I am moving this discussion to the Variable Resistor Solutions area of the Community, and thank you for being a menmber.
    Thank you,
    Jamie
    0 e14 Contributor over 13 years ago in reply to element14jamie
    this question was answered here:
    http://www.element14.com/community/thread/23967
  • element14jamie
    0 element14jamie over 13 years ago in reply to e14 Contributor
    Jamie
