Passive Components
Passive Components
Forum Capacitor replacement
Join Passive Components to participate - click to join for free!
  • Replies 26 replies
  • Subscribers 112 subscribers
  • Views 4066 views
Hello everyone!
I would need your help solving a little problem where I am not sure of the value of a capacitor that I need to replace.
I have never seen a capacitor like this one (yep, I'm a noob) so I searched online for some info and I though I could read it's value...the problem is that when I desoldered it from the board I noticed that on the other side it had other things written that, to my little knowledge, suggest a different value. Here are the pictures:
From this one I read that the precision is B, and the value is 4.1 uF with max 400v. The rest of the letters I have no idea what they mean.
From this one I read that it is a 4,7 pF capacitor and the precision is M. The rest I do not understand.
What I would really like to know is what the actual value of the capacitor is and if possible, what the various things on both sides mean so that in the future I will be able to read them.
Thank you very much in advance
    mcb1 over 11 years ago +1
    Typing 472M into google gives you 26,700 replies or thereabouts. http://www.csgnetwork.com/capcodeinfo.html Your out by a long way ... Why are you thinking that is the problem.? I'd be looking more at…
    mcb1 over 11 years ago in reply to e14 Contributor +1
    Do you suggest replacing both the resistor and the capacitor at this point? Why? If the value of the capacitor (now you have it out) and the resistor are what they should be, then there is really no…
    e14 Contributor over 11 years ago in reply to mcb1 +1
    This is the main board from a 1970's/1980's tv...the power supply should be ok as it is a separate unit and I got it fixed a few months ago. The problem is that a few days ago the tv made a noise (like…
    0 e14 Contributor over 11 years ago in reply to mcb1
    Well the shop is probably capable of repairing the tv...the problem is that when I got the supply fixed I was very unhappy with the price. I know that many times people expect lower prices because they don't know how much time and effort it takes to repair this kind of stuff, but when I brought the TV I had already opened it and I told them where the problem was because it was very easy to spot. The only reason I brought the TV to them was because I didn't feel experienced enough to repair an old TV without risking to damage it. The point is, when I went back to get the TV, they charged me 80 bucks just to replace a capacitor. I don't find that to be fair since I know that it didn't take them much work...sorry for bothering you with this long story ahah
    0 jw0752 over 11 years ago
    Hi Francesco,
    Just out of curiosity, How does the resistance of the resistor compare to the value printed on it? I have seen these resistors fail and have a small arc form at the failure point. This arc can leave a dark metal deposit on a nearby part. I would begin by testing the resistor. If it has failed you will find that it is open circuited and will give no reading on an ohm meter. If you don't have a meter you can pick a cheap one up usually for less than $10. US.
  • peterjcs23
    0 peterjcs23 over 11 years ago
    472 I would expect means 4700pF...measure capacitance with a meter to check.
    0 e14 Contributor over 11 years ago in reply to jw0752
    Well the resistor should have a value of 8.2k and the meter shows 8.1k but I do feel a tiny bump on it with my finger. Could the resistor produce much more heat than usual while maintaining the correct value of resistance?
    0 e14 Contributor over 11 years ago in reply to peterjcs23
    I don't have a meter capable of measuring capacitance but looking at the tables from the links in the answers above I'm pretty sure it's 4700 pF. Thank you
    0 jw0752 over 11 years ago in reply to e14 Contributor
    Hi Francesco,
    The 8.1K is close enough and indicates that the resistor is not the problem. The bump is probably just a little extra ceramic. The mark on the capacitor may be left over from a previous problem. The circuit may have to be checked out under power and since this is a high voltage area it will probably be best to bite the $bullet$ and take it to the TV service guy.
    Thank you very much for your suggestions. I will try my best to figure out what is wrong with the board on my own but if I cannot solve the problem I'm gonna eventually have to bring it to the shop
  • peterjcs23
    0 peterjcs23 over 11 years ago in reply to e14 Contributor
    okay, perhaps you should try to replace the capacitor, it is damaged. For example from Farnell..C947U472MYVDBA7317 - KEMET - CAP, CER, Y5V, 4700PF, 400VAC, RAD | Farnell element14 ...Peter
    Ok, so, after some tinkering and testing I think I might have found the problem...but still, as I am used to, I have a doubt. Here is what I found.
    There is a transistor (pretty big one) that does not seem to have any visual damage on it but when I tested it I got the following results:
    pin 1 (positive lead multimeter) to pin 2 (negative lead multimeter) gave me the same resistance (almost, slightly higher) as pin 3 (positive lead multimeter) to pin 2 (negative lead multimeter) so I am thinking this is a PNP transistor,
    and since pin 1 to pin 3 gave me no resistance I am thinking the transistor is damaged.
    The "only" problem is that if I search for the code on the transistor (C3892A) on google I can only find datasheets for NPN transistors that go by that name.
    I am seriously confused right now. If you could give me some advice on this I would greatly appreciate it
    Here is the complete list of values from the multimeter:
    pin 1 (positive) to pin 2 (negative) reads 406;
    pin 1 (positive) to pin 3 (negative) reads 40 and beeps;
    pin 2 (positive) to pin 1 (negative) reads 1;
    pin 2 (positive) to pin 3 (negative) reads 1;
    pin 3 (positive) to pin 1 (negative) reads 40 and beeps;
    pin 3 (positive) to pin 2 (negative) reads 431;
    0 mcb1 over 11 years ago in reply to e14 Contributor
    Franceso.
    Really quick reply from the airport.
    Try searching for a 2SC3892A.
    They usually drop the 2S to save room.
    Most transistors don;t show well unless you can bias the base with a finger or resistance to force it to conduct.
    Robert Peter Oakes
    Peter can you help in my absence.....image
    cheers
