Passive Components
Passive Components
Forum Sourcing low quantities of EXB-2HV432JV resistor array 4.3K
Join Passive Components to participate - click to join for free!
  • Subscribers 110 subscribers
  • Views 1616 views
  • sourcing
  • resistors
  • sources
  • resistor
  • array
  • exb2hv
Hi all,
In a bit of a pickle.  Having a board made and populated.  The board has been made and on to the assembly stage, it has two EXB resistor arrays on it.
One of them is a 6.8K, which they had in stock and have populated, the other is 4.3K, which they did not have.  On being made aware of this I said that I would source and solder the 4.3K one (EXB-2HV432JV).
Unfortunately I can only find them in quantities of 5000 minimum, and I only need ONE! http://www.findchips.com/search/exb-2hv432jv
Can anyone find me (or does anyone have) a small quantity of this component? I am in Nottingham, UK.
Thank you very much,
Alex
    shabaz over 11 years ago in reply to e14 Contributor +1 verified
    4.7k and 47k resistors in parallel will give you 4.3k to under 1% - if you really need that level of tolerance. So, you could piggy-back a 4.7k and 47k on top of each other. By googling I noticed there…
  • clem57
    0 clem57 over 11 years ago
    Other than getting 5K, check if they will let you sample a few especially if what you do has commercial value and therefore follow on order.
    Clem
    PS. Do you know anyone with a commercial account to sample them for you?
    0 e14 Contributor over 11 years ago in reply to clem57
    I don't know anyone who could request a sample for me unfortunately.  Due to the trouble this is caused I have emailed back to see if a 5K resistor can be fitted in its place.
  • clem57
    0 clem57 over 11 years ago in reply to e14 Contributor
    But the SMT mounted resistor looks more pro. May I ask what this will be when finished?
    Clem
    0 shabaz over 11 years ago in reply to e14 Contributor
    So, you could piggy-back a 4.7k and 47k on top of each other. By googling I noticed there are single quantities of those values available (just change the part number digits 432 with 472 and 473 which will correspond to 4.7k and 47k resistors respectively).
    It might not be easy to piggy-back them, but might be feasible for a 1-off if you take some time with it (small soldering iron and good tweezers to hold it exactly in place).
    This part of the circuit has 2 resistor arrays for stepping down a few digital logic lines.
    0 e14 Contributor over 11 years ago in reply to shabaz
    after being told they had no 5Ks, I went ahead, and as you said there are singles of these values avaliable (weird)
    thank you so much
