Passive Components
Passive Components
Forum Help identifying these SMT passive components - B&O ICEpower 200ASC
Join Passive Components to participate - click to join for free!
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 112 subscribers
  • Views 2581 views
Whilst I was working away, my wife had a house party and got trigger happy with the hifi volume. It's blown some components on the B&O ICEpower 200ASC modules which I'd like to try and fix myself. Problem is, I'm having a hard time identifying the components...
High res pictures of the before & after are here: https://goo.gl/photos/xxS2YiMSdZsxvKh9A
Here's what I think I know about the resistor so far...
R020 Resistor - Yageo RL1218FK-070R02L (http://www.yageo.com/documents/recent/PYu-RL_521_RoHS_L_6.pdf) 1218 Package (Long side termination)
But the inductor is a mystery - I can't find an ON Semiconductor 733MX device, but as far as I can tell, it's a 1812 package, 73uH SMT inductor, but they don't seem to exist with other suppliers either image
Many thanks for ANY help possible (components - not the wife...I'll sort that later)
Cheers
Gareth image
  • johnbeetem
    johnbeetem over 11 years ago +1 verified
    shabaz is correct -- it appears to be a Zener diode. I did a Google search for "Onsemi marking 733 MX" and got this: http://www.onsemi.com/pub_link/Collateral/1SMB5.0AT3-D.PDF According to page 3, "MX…
    0 shabaz over 11 years ago
    On semi do not offer inductors. The marking L201 refers to the large wound inductor just off the photo (although it is close to the on semi device).
    No idea what the on semi part is though - most likely a diode of some sort, e.g. schottky diode, or some other diode.
    0 e14 Contributor over 11 years ago in reply to shabaz
    Hi shabaz,
    Ah, good spot - that'll explain the directional band then. I'll keep searching along the diode front.
    Meanwhile, the hunt for the resistor continues image
    Cheers
    Gareth
  • johnbeetem
    0 johnbeetem over 11 years ago
    According to page 3, "MX" means it's a 1SMB48AT3G 48V Zener.
    0 e14 Contributor over 11 years ago in reply to johnbeetem
    Thanks so much! I've been struggling with that for a good while! They're in the shopping basket - thanks again!
    Do you think I'm on the right lines with the resistor? You can find 1218/1812 resistors, but very few are 0.02 OHM and the Yageo RL1218FK-070R02L is the only one I can find with the long side termination at that value/package.
    Cheers,
    Gareth
    0 shabaz over 11 years ago in reply to e14 Contributor
    Hi Gareth,
    That is a 0.02 ohm resistor as you say, and you'll need one of the same size (since a larger one won't easily fit) due to the power requirements (which you won't know).
    Basically you could just measure the dimensions and find a similar sized one. This one looks roughly the right size:
    ERJC1CFR02U - PANASONIC ELECTRONIC COMPONENTS - RESISTOR, 0.02OHM, 2W, 350PPM, SMD | Farnell element14
    I'd probably pick that one, it is low cost too.
    I've put an order in - many thanks for your help! Fingers crossed image
  • rfschmitzu
    0 rfschmitzu over 8 years ago in reply to e14 Contributor
    Hi there,
    I also had the same problem with overheating of the resistor and zenor diode. I followed the same approach and replaced the two capacitors next to the zenor diode (one of these had blown out), the Zenor and the 0.02 ohm resistor. I then applied power and nothing else connected to the board and the same components started to heat up rapidly. I disconnected the power and then took a further look at resistance of the components in general ie inductors resistors and transistors. I then found that two of the MOSFET transistors (marked 400N06N) were closed circuit and shorting out the output stage. I de soldered 2 of the four which had a short (the 2 nearest the 0.02 ohm resistor marked R020) and re connected the power supply. None of the components appeared to heat up at all so I am taking a guess that these are most likely the cause of the failure of the resistor and zenor. I have ordered replacement MOSFETS here:
    https://au.mouser.com/ProductDetail/Infineon-Technologies/IPD400N06N-G/?qs=sGAEpiMZZMutXGli8Ay4kJR0AeOXfgqWqALtgsH3p1M%3…
    So not a very scientific approach but it would make sense that the MOSFETS suffered from the overloading this may be the answer. I am yet to receive the components and do the repair. If anyone is out there wanting feedback let me know.
