Passive Components
Passive Components
Documents SCHURTER expands DC filter PEM 5003 with flexible wire leads and PCB mounting
Join Passive Components to participate - click to join for free!
  • Author Author: schurter
  • Date Created: 14 Oct 2010 8:57 AM Date Created
  • Last Updated Last Updated: 7 Oct 2021 7:31 AM
  • Views 747 views
The 5003 features a standard DC connector, offered in two different connector styles. The connector is encased with a 1-stage filter for currents up to 15 A at 125 VDC. The unit mounts to the equipment enclosure with a broad metal flange, thus providing a large contact area for optimal shielding and filter efficiency.
The PCB mounting style version is available with optional snap feet to safely fasten the 5003 on the printed circuit board. The flexible wire leads allow easy, fast and cost saving installation. Screw-on, snap-in and rivet mounting options are offered. The rear mount type with pre-threaded holes, as well as the snap-in, are designed specifically to reduce assembly time and save labour costs.
The series is ENEC and cURus approved and complies with IEC/EN 60950, applicable for information technology equipment, including electrical business equipment and associated equipment. Applications include telecom and IT infrastructure equipment, data encryption machines and other DC supplied equipment in industry automation.
Technical Features:
- DC appliance inlet with EMI filter
- Current ratings: up to 15 A at 125 VDC (ENEC/UL/CSA)
- Mating connectors: Molex HCS-125, AMP universal MATE-N-LOK
- PCB mounting / flexible wire connection / Quick connect terminals / Solder terminals
- Screw-on or rivet mounting from front or rear side / snap-in mounting
Resources:
Data Sheet 5003 - http://www.schurter.ch/pdf/english/typ_5003.pdf
New EMC Products - http://www.schurter.ch/products/product_news.asp?sge=emc
EMC-Products - http://www.schurter.ch/products/emc_overview.asp?language_id=10
Selector Power Entry Modules with Filter - http://www.schurter.ch/wwwsc/con_pg06.asp
About SCHURTER Group
The SCHURTER Group is headquartered in Lucerne (Switzerland) since 1933. SCHURTER is an internationally leading innovator and manufacturer of fuses, connectors, circuit breakers, input systems and EMC products as well as a PCB assembly service provider. Our industries span telecommunications, IT, medical and measurement technology sectors, emerging food & beverage and alternative energy industries. The major country-specific certifications including VDE, ENEC, UL, CSA, CCC, METI or KTL are evidence of our high quality and absolute reliability in each product.
Contact: info@schurter.com.sg
Website: www.schurter.com
  • entry
  • appliance
  • iec/en
  • emi
  • curus
  • enec
  • inlet
  • with
  • dc
  • power
  • filter
  • module
  • 60950
