Power & Energy
Power & Energy
Alt Energy Solutions & Tech Engineers to maximize solar power potential
  • Author Author: Eavesdropper
  • Date Created: 12 Jan 2011 7:32 PM Date Created
  • Views 473 views
  • Alternative Energy Tags
  • solar
  • solar_cell
Eavesdropper
Eavesdropper
12 Jan 2011
Solar power is becoming a major player in alternative energy sources and scientists are looking to make that power source more efficient. Engineering professor Jan Kleissl, from UC San Diego, is working on technologies and methods that will better predict how much power we can actually harness from the sun. Kleissl and his Ph.D. student Matt Lave explain why it’s important to strategize on solar installation, depending upon the location of the building relative to the sun. For example, Kleissl and his students at the UC San Diego Jacobs School of Engineering have improved the solar map for the state of California, which allows homeowners, photovoltaic installers and utilities to better predict how much energy they will get out of their solar systems.  The map can be viewed via Google Earth for free. “Probably the most important result of this work for California is that in all coastal areas (Los Angeles, San Francisco, San Diego) it is advantageous to install the panels facing about 10-degrees west of south, this not only optimizes energy production, but it also improves the correlation of solar power production with the load. Panels facing southwest ‘see’ the sun longer and at a better angle than panels facing south, which means that the energy generated is larger during the peak demand hours (3-to-5p.m.), making the energy more valuable. The generally clear conditions during the annual load peaks (also known as Santa Anas to Southern Californians) mean that the solar panels produce at the optimum power,” said Kleissl.
Eavesdropper
