Power & Energy
Power & Energy
Forum Have you tried digital power control?
  • Subscribers 284 subscribers
  • Views 514 views
  • exar
  • management
  • xrp7714
  • power
awinning
awinning over 15 years ago
I'm running this RoadTest to give away Exar's XRP7714ILB-FXRP7714ILB-F http://www.element-14.com/community/view-event.jspa?event=2607.for users to test and review
I wondered if anyone had used digital power control and how they found it.
  • Jorge_Garcia
    Jorge_Garcia over 15 years ago
    HI Alistair,
    I've played with some of the reference implementations the Microchip has produced for their DSPIC33FJ16GS504-I/MLDSPIC33FJ16GS504-I/ML and 502 products. The algorithms used in the implementations is a digital PID loop and in my experience they work very well. Out of the box they aren't optimized for transient response but they are functional.
    I very much like the idea of digital control, because it offers the programmer a great deal of flexibility. For example at light loads switching power supplies cross the boundary from continous conduction to discontinous conduction modes. One could program a different set of compensation variables depending on the load so that the power supply is always optimally compensated.
    The greatest advantage in my opinion is the ability easily adjust the compensator parameters through software, instead of having to swap resistors and capacitors in the compensation loop.You can adjust for various voltage and current output combinations all in software, which makes prototyping a snap.
    I presume your experience will also be positive and with some tweaking you can ring alot of performance out of power supply designs.
    hth,
    Best Regards,
    Jorge Garcia
    Cadsoft Computer
  • enrico.migchels
    enrico.migchels over 15 years ago
    Hi Alistair,
    Like Jorge, I tried and tested a Microchip reference design on digital control. It was a 300W AC/DC converter with PFC, full bridge 12V ZVS converter and multi-phase buck converter. There are 2 DSPic in the design driving 18 FET's (some in parallel), very impressive design. The multi-phase buck (3V3/80A) drove a short circuit (piece of thick copper wire in a water tank). It was stunning to see that the supply was apply to drive the short from startup.
    I have samples on my desk of DSPic, in the near future i will have to make this stuff myself :-)
    Best regards, Enrico Migchels
  • awinning
    awinning over 15 years ago in reply to enrico.migchels
    Hi guys,
    Thanks for the responses. The article on page 24-25 here may be of some use http://www.element-14.com/community/docs/DOC-22247
