Power & Energy
Power & Energy
Forum how to choose "PNP-NPN" mosfet transistors?
  • Subscribers 283 subscribers
  • Views 822 views
how to choose "PNP-NPN" mosfet transistors, which operates more than 13.56 MHz and around 3 amp?
what is the right way to look for a transistor with such specific values?
  • robotonics
    robotonics over 14 years ago
    Hi
    What application will be you be using them for?
    e14 Contributor over 14 years ago in reply to robotonics
    switching application ..
  • YT2095
    YT2095 over 14 years ago
    I gather from the freq that you`re interested in the ISM band, you mention 3 Amps, but most RF power transistors are rated in watts for practcal applications, so what sort of Voltage are you thinking? I``m guessing 13.8?
    e14 Contributor over 14 years ago in reply to YT2095
    yes exactly, ISM band..
    im using a transformer with a center tap as my supply which provids (+12)- 0- (-12) Vac @ 3 A ..
    Im going for  12 Vac as for this time..
