Power & Energy
Power & Energy
Forum A magnetic VA wind turbine for your home, gives out 10 kw, and small...can you make this?
  • Subscribers 281 subscribers
  • Views 245 views
Hi, I'm no expert on this subject, but I was wondering, can you make a "magnetic" Vertical axis wind turbine to create 10kw and small(or at least smaller than other 10kw turbines) and hooked up to your home?
when I say magnetic, I mean replace the turbine blades with magnets(or fix magnets on the blades), have another set mounted to create that constant movement for the generator, that way you wouldn't have to rely on wind anymore, and you could make a weatherproof box for it, hooked to an inverter and then to the fuse box.
could this work?
