Power & Energy
Power & Energy
Forum solar panel repair,
  • Subscribers 280 subscribers
  • Views 1012 views
solar panel repair,
Solar panel. Has a 3 pole outlet with two wires + - the diodes connect the 3rd.,one diode to pos. one diode to neg.
    jw0752 over 11 years ago +2
    Hi Stephen, The diodes may be there to remove static or unwanted voltage spikes and conduct them to ground. I unfortunately did not understand precisely what you were asking so perhaps you can clarify…
    0 jw0752 over 11 years ago
    Hi Stephen,
    The diodes may be there to remove static or unwanted voltage spikes and conduct them to ground. I unfortunately did not understand precisely what you were asking so perhaps you can clarify what your question is and add a picture or a diagram so we can get you a good answer.
    Perhaps element14jamie can move your question to a more appropriate group to be answered.
  • element14jamie
    0 element14jamie over 11 years ago in reply to jw0752
    Hello All,
    I will move this over to the Power & Energy area as it is a better fit
    Thank you,
    Jamie
