Power & Energy
Power & Energy
Forum Looking for durable thermal pad between Tec hot plate to DUT
  • Subscribers 283 subscribers
  • Views 888 views
Hi:
I am looking for material to be used as a thermal pad between the interface of Tec hot plate to the device under test (DUT). This thermal pad need to be durable as I need to change the DUT frequently after done the test. I ordered the thermal pad (
T GLOBAL  PC94-150X150X0.5PC94-150X150X0.5 THERMAL PAD 0.5MM 4W/M.K RED ) below:
PC94-150X150X0.5 - T GLOBAL - THERMAL PAD, 0.5MM, 4W/M.K, RED | element14 Singapore
But found out that it is not durable. I can not reuse it for the next DUT.
Thank you.
Chin Lin
    0 jw0752 over 10 years ago
    Hi Chin Lin,
    You did not mention the temperature range that the pad must be able to tolerate. I see that the one you have is only good to 105 degrees C. From my experience with dental sterilizers I know that some of the heating elements come encased in red RTV and can tolerate a much higher temperature. The specifications on the RED RTV that I have in the shop can go as high as 350 degrees C. You may want to check to see if this will work better for you.
    Hi Chin,
    I am very professional on thermal interface material including thermal pad,what you bought from T-Global is thermal pad without fiberglass inside,so its tensile strength is very low and easy to be broken,not durable.
    Pls contact me,and I will arrange samples for your testing,this is our company website     www.hzliwang.cn  Thanks!
  • justinhotban
    0 justinhotban over 9 years ago
    I advise you ask SinoGuide thermal team, open discussions for any design problems
    SinoGuide Thermal Team Specializes in The Following Major Areas:
    Thermal Simulation Analysis – Flotherm Software and Fluke Thermal imaging cameras
    Thermal Management - Analyzing the problem, Planning the solution, Finding the suitable products
    Thermal Products - Thermal Conductive Grease/ Pads/Tape/Putty/Insulator
  • justinli
    0 justinli over 9 years ago in reply to justinhotban
    Happy New Year 2017,and thanks for your inquiry of the thermal pad from our website.
    I have just taken a short view from your website,and it is quite interesting as finding out your company have already brought the gap filler into your product portfolio.
    Would it be possible to know some your previous supplier infos?
    If it is confidential,may we SinoGuide Team knows where is the origin country due to the concern of different testing method for the thermal conductivity?
    Regarding your required brochure,pls find attached for you and your team reference.
    If able to know your chosen type with related dimension and quotation,we could give our cost for your budget reference.
    Thanks for your kind notice,and look forward to hearing some your updates.
