Power & Energy
Power & Energy
Forum 5V, 2amps power supply schematics
  • Subscribers 282 subscribers
  • Views 912 views
  • iot
kosme
kosme over 8 years ago
I have been working for a couple of months on an IoT project that controls AC through a triac. The project works quite well but to shrink it, I took apart a Raspberry Pi, 5V 2Amps power supply and soldered the input to the AC line and the output to the logic of the device, with excellent results. This works quite well for prototyping but now I want to scale production and tearing apart power supplies is not an option. So I am looking for the schematics of a power supply that works in a similar way of the ones that are used to charge phones/tablets, power single board computers, and similar stuff. Any help?
    jw0752 over 8 years ago +2 suggested
    Hi Enrique, Have you given any thought to reverse engineering the one that you have? As long as the board isn't more than 2 layers you should be able to figure it out and draw a schematic. Personally I…
    Hi Enrique, Here is an example of what I am talking about: http://www.ebay.com/itm/SM-PLF12B-12W-5V-2A-12W-SMPS-Switching-Mode-Power-Supply-Switch-Power-Supply-/162214190762?hash=item25c4b81eaa:g:1XgAAOSwCGVX3k2m…
    0 jw0752 over 8 years ago
    Hi Enrique,
    Have you given any thought to reverse engineering the one that you have? As long as the board isn't more than 2 layers you should be able to figure it out and draw a schematic. Personally I would probably buy commercial converters and salvage the boards like you did for your prototype.
    Hi Enrique,
