Power & Energy
Power & Energy
Forum Any recommendations for li-Ion batteries?
  • Replies 17 replies
  • Answers 14 answers
  • Subscribers 281 subscribers
  • Views 3902 views
  • li-ion or li-po battery
genebren
genebren over 8 years ago
Greetings!
I have been working on building a li-Ion battery charger/power pack for a robotics project.  I bought some UltraFire 14500 batteries rated at 1200mAh (Ebay), but in my testing, these batteries only only seem to have 220-365mAh of capacity.  Any recommendations for reliable vendors/brands of li-Ion batteries?
Thanks!
Gene
    shabaz over 8 years ago +6 suggested
    The ultrafire name reminded me of a school project.. We had to build a toy for less-abled children, so we basically made a radio controlled car (using off-the-shelf remote control) and the thing was heavy…
    jw0752 over 8 years ago +5 suggested
    Hi Gene, I would look for batteries used in a commercial application. If you buy the OEM batteries for a product and then salvage them you are likely to get good quality as the manufacturer has his name…
    shabaz over 8 years ago +4 suggested
    Hi Gene, For cylindrical Li-Ion, I've used cells from Farnell, and they are great, but the price may not suit all hobby needs (I don't know if you're looking for a commercial project or not). For flat…
    0 genebren over 8 years ago in reply to shabaz
    Nice project.  That looks like some serious fun.
    Yeah, smoke is all around us in the business/hobby.  Some times it all comes out at once and we are left with a charred mess.  Sometimes the smoke stays in and we feel like we can do anything.
    I have performed some maximum smoke tests for commercial products, where we purposefully attempt to create a worst case scenario. We would disable all of the safety features (auto shutdown, etc.) and basically short out the Li-Ion battery with a High power laser diode (via multiple 100A Mosfets), then drop the device into a metal trash can and watch for flames.  There was usually some bad smells and scary noises, but never any really flames (we did keep a fire extinguisher on hand). Under normal operation the device was capable of shorts bursts of 100A across the laser, we just switched into 'full on mode'.
    Gene
    0 shabaz over 8 years ago in reply to genebren
    Hi Gene,
    Ahh sorry - I had used an 18650 sized Li-Ion from Farnell/Newark. I've not used a AA size Li-Ion before. There is a Panasonic Industrial UR14500P, 800mAH. looks quite nice..  TME and Conrad stock it, Conrad price in USD is about $8.60 (both are based in Germany, so unsure on shipping cost : ( They are reputable sources though as I understand. I've purchased from Conrad once and the postage costs were not excessive, so if you want to purchase but delivery charges are too high to USA, let me know since I can ship it to you.
    0 genebren over 8 years ago in reply to mcb1
    mcb1
    Great information! (I have a little more reading to do now).
    My charger is basically setup for a "2 x Capacity in term of time" charge profile.
    Charging at ~500mA, the battery completed charge in ~50min, which works out to roughly the reduced capacity level that I am seeing.
    I used to use a very similar statement about Li-Ion batteries to my students as part of the 'lab safety' lecture.
    Thanks!
    Gene
    Shabaz,
    Thanks, I have heard great things about these batteries.  The only problem that I see is that the battery holder that I am using is "polarity protected".  It protects the positive terminal with plastic ridges, so that only a 'button top' battery can contact the terminal.  The flat tops on these Panasonic/Sanyo batteries might not be able to make contact.  I guess I can find out by getting some and trying it out (or by trimming the ridges to allow contact).
    Thanks!
    Gene
    Shabaz,
    I found out that there is a non-polarity protected version of the battery holder that I am using, so I will order that, along with a pair of these batteries (I found them in the USA with reasonable shipping).  It will be interesting to add some more test points to my Li-Ion battery tests.
    Thanks!
    Gene
    0 jw0752 over 8 years ago in reply to jw0752
    For the fun of it tonight I ran the same test for mAh on a 18650 battery that was likewise salvaged from a computer battery pack. Since the 18650 has 30% more volume than the previously tested 18500 I expected a 30% increase in capacity or about 1300 mAh. Instead I found nearly 2000 mAh. Obviously there is more to a change in size than just the volume. Anyone know if this difference is chemistry or different mechanical structure?
    0 genebren over 8 years ago in reply to jw0752
    John,
    As far as I know the chemistry of the cells are the same.  There are construction differences with each of the cell form factors that can change the overall capacity, like total length of the electrodes (longer, thinner electrode have greater surface area and therefore higher capacity).
    Gene
