Power & Energy
Power & Energy
Forum Electromagnet powering
  • Replies 13 replies
  • Answers 8 answers
  • Subscribers 285 subscribers
  • Views 6235 views
thotslayer2019
thotslayer2019 over 7 years ago
Hello all.
I am thinking of buying an 12V electromagnet  for various projects.This magnet is a 50mm, 50KG DC magnet.
But before I buy it I need to know how to power it off some 1.5 batteries.Also is there any other cheap way to power it?
So the power - what things will I need ( they need to be cheap, havent got much money) ?
Could I use a transformer that does 1.5 -12V, could I buy a boost converter?
Really, what do you lot think?
Thanks.
  • 14rhb
    14rhb over 7 years ago +6 verified
    Hi Tom, Sounds quite like it would need quite a lot of power to maintain that pull (and power is voltage x current). Looking up a typical device on the spec you provided here gives a current requirement…
  • fmilburn
    fmilburn over 7 years ago in reply to thotslayer2019 +5 suggested
    Hi Tom, Your friend is most likely incorrect - see Rod's estimation of the requirements above which are far below what 4 car batteries would deliver. In order to get meaningful help you will need to better…
  • 14rhb
    14rhb over 7 years ago in reply to thotslayer2019 +5 suggested
    Not wanting to ruin an interesting idea but, to get the full pulling force of an electromagnet you'll need to ensure all the magnetic flux couples directly into the ferrous item you are attaching to. A…
    0 shabaz over 7 years ago
    Hi Tom,
    As many have mentioned, some things are rule-of-thumb and experience-based, and some practicality based on the use-case (since we know that no lamp post is perfectly flat, or perfectly cylindrical), so there can't be a precise recommendation, but from general experience and first-level estimates, it is clear it would not consume 4 car batteries per second.
    If you actually wanted to derive everything and calculate it all, it would be quite a large exercise - lots of maths and still many things would be severe guesses since not all input information would be available (down to specific material compositions even, to know if it could lift 50kg, temperature rise, etc).
    It will require experimentation basically.
  • thotslayer2019
    0 thotslayer2019 over 7 years ago in reply to Fred27
    Hi.
    I will not necessarily use this project for lamposts - that was an example of something I could do.
    Thanks though for the permanent magnet links.
    Looks interesting
  • thotslayer2019
    Look. All im asking is if you have any suggestions for kit I should use?
    Oh and also. This is the electromagnet I was going to buy.
    I might be at least 2.
    https://www.amazon.co.uk/Electric-Lifting-Holding-Solenoid-Electromagnet/dp/B00LWY8SZC/ref=mp_s_a_1_3?ie=UTF8&qid=1536749757&sr=8-3&pi=AC_SX236_SY340_QL65&keywords=electromagnet+12v+dc&dpPl=1&dpID=41hOeXP1twL&ref=plSrch
