Power & Energy
Power & Energy
Forum Electromagnet powering
  • Replies 13 replies
  • Answers 8 answers
  • Subscribers 285 subscribers
  • Views 6163 views
thotslayer2019
thotslayer2019 over 7 years ago
Hello all.
I am thinking of buying an 12V electromagnet  for various projects.This magnet is a 50mm, 50KG DC magnet.
But before I buy it I need to know how to power it off some 1.5 batteries.Also is there any other cheap way to power it?
So the power - what things will I need ( they need to be cheap, havent got much money) ?
Could I use a transformer that does 1.5 -12V, could I buy a boost converter?
Really, what do you lot think?
Thanks.
  • 14rhb
    14rhb over 7 years ago +6 verified
    Hi Tom, Sounds quite like it would need quite a lot of power to maintain that pull (and power is voltage x current). Looking up a typical device on the spec you provided here gives a current requirement…
  • fmilburn
    fmilburn over 7 years ago in reply to thotslayer2019 +5 suggested
    Hi Tom, Your friend is most likely incorrect - see Rod's estimation of the requirements above which are far below what 4 car batteries would deliver. In order to get meaningful help you will need to better…
  • 14rhb
    14rhb over 7 years ago in reply to thotslayer2019 +5 suggested
    Not wanting to ruin an interesting idea but, to get the full pulling force of an electromagnet you'll need to ensure all the magnetic flux couples directly into the ferrous item you are attaching to. A…
  • 14rhb
    0 14rhb over 7 years ago
    Hi Tom,
    Sounds quite like it would need quite a lot of power to maintain that pull (and power is voltage x current). Looking up a typical device on the spec you provided here gives a current requirement of 0.84A - you'd need a bank of 8x AA batteries and they wouldn't last very long. You could get away with rechargables though if you wanted something portable and the electromagnet isn't constantly energised.
    A standard 'wall-wart' transformer left over from some other gadget could be repurposed; e.g. the mains transformer, usually black plastic casing, that plugs straight into the mains voltage (240v/115v) and powers things like routers, printers, external lights.
    Something with a rated output of 12v-2A perhaps to give you some margin for running continuously. I'd opt for a DC output (as you can use it for other projects) but the electromagnet should work fine on 12v AC as well IMHO. These cheap transformers often don't run at the specified voltage, open circuit they are usually quite a bit higher, but for your application I don't think it would be an issue. Have a tinker and see - keep a check on the current/voltage (if you have a suitable meter) and failing that, ensure the transformer and your electromagnet don't get too hot.
    Rod
    • Vote Up +6 Vote Down
  • thotslayer2019
    0 thotslayer2019 over 7 years ago in reply to 14rhb
    Thanks a lot!
    I would preferably like to make the electromagnet and power supply portable so I, myself, would opt for DC power and a battery bank.
    So I have also spoken to a friend about this and he said it might take the same voltage and current of using 4 car batteries a second.Does a 12V electromagnet take that much power?
    Also, have you got any suggestions as to what type of transformer I could use because, honestly, I have no idea what to use!
  • fmilburn
    0 fmilburn over 7 years ago in reply to thotslayer2019
    Hi Tom,
    In order to get meaningful help you will need to better define what your constraints and requirements are.  E.G.
    • Do you want to power it from the wall or batteries
    • If batteries, how long do the batteries need to last
    • How are you going to package the device - e.g. electronics and power in a box with magnet connected by wires
    • Indoors or outdoors
    • How much do you want to spend
    • Etc.
    • Vote Up +5 Vote Down
  • thotslayer2019
    0 thotslayer2019 over 7 years ago in reply to fmilburn
    Ok so...
    I want too make it portable to batteries are a must
    How long do the batteries need to last?
    Dont know, any amount of time ( more preferably around 1 minute.
    I was hoping to have the electronics and batteries in a back pack with the magnet strapped to my hand.
    Outdoors is what I am planning my project for -might be a bit crazy but im hoping for this to be a beginner projects into electronics ( use- climbing lamposts/ climbing up low metal objects)
    The general costs - I would be willing to pay about £200 for different parts.cannot go over £250.
    Thanks!
  • 14rhb
    0 14rhb over 7 years ago in reply to thotslayer2019
    Not wanting to ruin an interesting idea but, to get the full pulling force of an electromagnet you'll need to ensure all the magnetic flux couples directly into the ferrous item you are attaching to. A lamppost, being convex, wouldn't work properly with the flat surface of the electromagnet...the air gap would significantly weaken the force below 50Kg. You may still have issues with flat metal plates when the pulling force is tangential to the surface i.e. the magnet will slip.
    I also don't think I'd want to be up a lamppost when the battery voltage dropped and the pulling force proportionally so image. Saying that, you could build in some cool way of measuring battery capacity and thus warning of impending doom.
    p.s. can you not just use a ladder image
    Rod
    0 jw0752 over 7 years ago
    Hi Tom,
    There is another consideration and that is heat dissipation. Your electromagnets are going to get hot. The other commentators have made really good points about the uncertainty of the strength of the magnets under different conditions. The 50 Kg specification is likely a measurement taken under ideal conditions. Climbing would necessitate a switching off of each magnet so that the next step could be taken. I would guess the best policy would be that any one magnet could support the entire weight. If you climb over 6 feet off the ground you may want to have the fire rescue on speed dial.
  • msebok
    0 msebok over 7 years ago in reply to jw0752
    Also this hasn't been touched on regarding safety. Typically magnets take more force to PULL an object before releasing then they do with a sliding action. With that said be careful with it.. lol
  • thotslayer2019
    Thanks Everyone.
    Basically I will worry about safety later - for now I need information on how to power the electromagnet on batteries, as well as heat dissipation/cooling system, and any monitoring systems that could be used to monitor power/temp/current.
    Literally I know almost nothing about putting one together and how everything should fit together.
    And no one say anything about how if I dont know how to put one together, I shouldnt be attempting it.This is for fun.
  • 14rhb
    Hi Tom,
    May I suggest you spend a small proportion of your funds an a Digital Multimeter ( if you haven't already got access to one ).
    Something like this Product LinkProduct Link  this could help you understand what is going on in terms of current and voltage as you progress your project.
    Rod
  • Fred27
    0 Fred27 over 7 years ago
    Using an electromagnet to climb a lamp post really isn't practical. The only way I can see that this might be possible is if you use permanent magnets in a similar way to you see in the magnetic base of a dial gauge. For instance something like this:
    https://www.amazon.co.uk/MAGNETIC-BASE-METRIC-GAUGE-INDICATOR/dp/B003W4SFSK
    This uses a couple of permanent magnets and the "switch" moves one of them so that the magnets can either work together or cancel each other out. They're surprisingly strong, although maybe not quite enough for what you had in mind.
