Power & Energy
Power & Energy
Forum Which PC/plastic-friendly corrosion cleaner is preferable if you only had just one?
  • Subscribers 283 subscribers
  • Views 325 views
hafcanadian
hafcanadian over 6 years ago
Seems like I’m always encountering a flashlight (I have probably way too many) that’s either suffered a leaky battery or aluminum/copper corrosion inside.  Detailed microbrushing and cleaning of the aluminum case and often a plastic battery holder and it’s contact inserts inside is a pain.  I then apply dielectric grease with a cotton swab to the contacts and any aluminum case deterioration.
The Newmark catalog shows many plastic-friendly cleaners, spray-on and otherwise, but which should I order that might be okay cleaning PC boards also?
    shabaz over 6 years ago +1 suggested
    Hi Joel, I use Isopropanol for almost everything.. There are 'MG Chemicals' 70/30 IPA wipes, that are really good on PCBs..
    0 shabaz over 6 years ago
    Hi Joel,
