Power & Energy
Power & Energy
Forum Unreliable SD memory card
  • Subscribers 282 subscribers
  • Views 1211 views
colporteur
colporteur over 6 years ago
Has anyone experienced an unreliable memory card when using a Micro SD card (small) in a Standard SD card (large)holder?
I am looking for insight into a video camera problem. The operator has indicated the Micro SD memory cards (tried a few) are intermittent when used with the standard SD sized card holders. I have ran through a gauntlet of questions about the cards and the setup but nothing stands out.
I have not experienced such a problem myself and I can't find any information that suggests there would be a problem with the adaptor cards. The operator insists using Mirco in the standard card holder is the problem. I thought I would ask before taking the camera into the shop.
Can you drop me a line if you have any knowledge?
Sean
  • beacon_dave
    beacon_dave over 6 years ago +1
    No, but I have noticed that some SD cards turn out to be a Micro SD card in a wrapper if you pull them apart and look inside.
  • ralphjy
    ralphjy over 6 years ago +1
    I've experienced issues with microSD cards but never because of using an adapter. I suppose you've already tried different types of microSD card (brands, size, etc).
  • colporteur
    colporteur over 6 years ago in reply to ralphjy +1
    An apologies for my tardiness in replying. I'm having some technical difficulties getting notifications lately. I have suggested a process to try and narrow down the issue. Those efforts have been met…
  • beacon_dave
    0 beacon_dave over 6 years ago
  • ralphjy
    0 ralphjy over 6 years ago
  • colporteur
    0 colporteur over 6 years ago in reply to ralphjy
    I have suggested a process to try and narrow down the issue. Those efforts have been met with the typically "tried that" response.  I also get responses like I think, I'm not sure and that should not cause a problem.  I'm not saying they are wrong but their testing methodology isn't rigorous. They don't have the resources or want to put the effort forward to isolate the problem.
    I use SD cards, all types and flavours, in many of my projects. I have never had an issue that points to the card holder. I thought I would throw out a request and see if my results are the norm.
    Sean
    0 shabaz over 6 years ago
    Hi Sean,
    I've not seen such an issue either, so this response is pure speculation and perhaps worthless : (
    Based on no evidence I've always (perhaps wrongly) considered the supplied adaptors to be temporarily/intermittently used to get data to/from the card when using them with a PC, i.e. I've thought of them as throwaway. They always looked flimsy to me. Maybe the adaptors are not intended for use over a long period of time.
    So, for any device that has a full-size slot, I've always purchased a full-size card basically.
