Power & Energy
Power & Energy
Forum ESD PROTECTION CIRCUIT
  • Answers 3 answers
  • Subscribers 283 subscribers
  • Views 1297 views
rajkiransingh
rajkiransingh over 5 years ago
Hi
I am looking for ESD circuit for my New PCB design. Can you help me with that.
As there is lot of Electrostatic charges developed around and causing problem while we touch it.
kindly provide me some protection circuit for PCB.
    dougw over 5 years ago +2 suggested
    There are many ICs that are designed to perform this function. Here is an example: 92K8997 92K8997
    0 dougw over 5 years ago
    92K899792K8997
  • aswinvenu
    0 aswinvenu over 5 years ago
    Hi Rajkiran,
       Do you want to protect the IO pins from ESD? Use TVS ( Transient Voltage Suppressor ) Diodes on the inputs.
    This gives a decent protection against ESD surge voltages.
    Aswin
  • rajkiransingh
    0 rajkiransingh over 5 years ago in reply to dougw
    Thank you so much Mr Wong. Can i get complete circuit how to interface it. Whether i have interface in the Power supply or the Controller ?
  • rajkiransingh
    0 rajkiransingh over 5 years ago in reply to aswinvenu
    HI Aswin, thanks for the suggestion. can you suggest me any specific TVS diodes . Area of this circuit application will be outdoor.
    0 dougw over 5 years ago in reply to rajkiransingh
    The chip connects to your power and ground and any signal you want to protect. The datasheet has an example schematic...
  • rajkiransingh
    Thank you so much Mr Wong, i will try this.
    And do you have any idea about precautionary steps to be take while designing A DC to DC Buck converter (Battery supply as a input) and Relay driver (DC geared motor as Load) ?
