Power & Energy
Power & Energy
Forum ULN 2003 Relay Driver
  • Subscribers 281 subscribers
  • Views 1267 views
  • power supply circuit
  • electonics
  • protection relay
  • electromechanical relay
  • relay module
  • relay noise
  • motor noise
  • electrical design
rajkiransingh
rajkiransingh over 5 years ago
  Am using ULN2003 driver ic to drive the 6 Volts relay. But i think this is not sufficient for any automotive application where their will be a huge noise, spikes , ESD etc., So in order to avoid that i need a proper guidance or circuit with maximum protection and isolation.
The load which am connecting to relay Normally open point is, "DC Geared Motors of 10v to 24 Volts 20Amps", and power source for the motor is Battery with sufficient voltage and current which is connected to the Common point of the relay.
Kindly help me that.
    0 dougw over 5 years ago
    A ULN2003ULN2003 seems able to drive a 35Amp P&B 1432785-1P&B 1432785-1 automotive relay.
    You may want to add a 1N40011N4001 snubber diode across the coil.
