Power & Energy
Power & Energy
Forum Dual Output Regulators
  • Replies 8 replies
  • Subscribers 283 subscribers
  • Views 1140 views
bnuthakki
bnuthakki over 15 years ago
Is there any regulator with 24V input and +12V and -12V ootputs with minimum load of 200mA. Please suggest me the best method for this requirement.
    0 e14 Contributor over 15 years ago
    If the Vin were less than +16V, then the Linear Technology LT3471EDD#PBF.LT3471EDD#PBF. could do it.
    If no then for +24Vin, you can use 2 x LT3580.
    Mike Grossman
  • bnuthakki
    0 bnuthakki over 15 years ago in reply to e14 Contributor
    Thanks Mike.
    Can I use this IC for ANALOG Circuits power supply without any noise due to ripple voltages.
    0 e14 Contributor over 15 years ago in reply to bnuthakki
    If done properly yes.  Contract your local LTC saels office for help with this design.
    http://www.linear.com/contact/
    Mike
  • bnuthakki
    Thanks Mike.
    Balakrishna Nuthakki.
      sorry, you can check  LM databook.
    Yes there is, er, are - a lot of them. There are lots of manufacturers but for example, the data attached is a Murata part, available from Mouser in the US.
    Jonathan Point
    imagekdc_nds6c.pdf
  • bnuthakki
    Dear Joanathan,
    Thanks. But Murata Power supplies are too expensive.
    Balakrishna.
    You didn't actually mention cost, although you did mention voltage and current.
    These devices are very cost-effective when you need a non-engineered solution. I have used them in several custom projects where the production quantity or time-to-market didn't justify the time and expense of R&D for the power supplies. Also, there are generic versions of these devices available from a number of Asian companies at 25-50% of the cost (in quantity). If you are manufacturing thousands of units per month, they probably aren't the correct solution.
    The final decision comes down to a lot of factors if you want to engineer the most appropriate solution. Cost is one. Do you have a budget for this section? This answer alone will determine whether you bother to engineer a solution or not.
    Jonathan Point
