Power & Energy
Power & Energy
Forum How to make a DC square waveform in high voltage
  • Subscribers 283 subscribers
  • Views 687 views
Hi  I am new here. But I have a qsn.
How to produce a DC square waveform in high voltage?  Source can from DC power supply ( 0 ~ 30V, one direction ) and SSO ( 230V  AC ). The high voltage is about 10kV.
Thanks. Guys.
  • JohnDSiviter
    0 JohnDSiviter over 15 years ago
    Hi Yi Yin,
    At what frequency are you wanting the square waves to be?.
    It sounds like you need a Oscillator connected to an Opto-isolator and an IGBT Output, however 10kV is still pretty high even for an IGBT!.
    What is your application?
    John.
    0 e14 Contributor over 15 years ago in reply to JohnDSiviter
    Hi
      Yar~ the frequency can be quite high, from 50Hz to 20kHz.
       This is used for high-voltage deinfection of liquid, we are doing research and testing, the power for DC square waveform is much lower than AC waveform.
      Thank you.
  • enrico.migchels
    0 enrico.migchels over 15 years ago
    Hi michelleyy,
    What you need is a solid state switch from Behlke (www.behlke.de). Those guys have all the goodies you need. I recently bought a high voltage switch from Behlke. I had to pay 1000 euro but it almost impossible to build a relaible switch for 10kV. You can use several IGBT's is series but you need to drive them also. It is difficult.....
    You can also try to find some electron tubes. I have some triodes (50kV) and Thyratrons (16kV). Those can also do the job but they are big and fragile. Be aware of X-Ray. :-)
    Best regards, Enrico Migchels
    0 e14 Contributor over 15 years ago in reply to enrico.migchels
    Hi Enrico Migchels
        Thanks for your reply.
        I found what I need is so difficult to build, I also tried some diodes and capacitors, but I think they will not work. Anyway, ask a company to customize for me may be the good. Thanks.  HaHa~
