Power & Energy
Power & Energy
Forum High side driver info ?
  • Subscribers 285 subscribers
  • Views 650 views
  • infineon
  • bsp452
Trevor@smithlab
Trevor@smithlab over 15 years ago
Hi All,
I have a few low volume designs using the BSP452 high side driver profet, which is getting difficult to obtain now.
Any recommendations for alternatives in similarly small packages ?
  • aflipse
    0 aflipse over 15 years ago
    ITS4141 is a direct replacement
  • icman
    0 icman over 15 years ago
    Hi Trevor
    just go to to www.infineon.com/profet and use the selection tool to find the right alternative; in the small package you might want to use the ITS4140N, ITS4141N or the ITS4142N or you switch to a different package and go with the BSP742/752 again it all depends on the specifications you are looking for so I would advice to use the selection tool
  • Trevor@smithlab
    0 Trevor@smithlab over 15 years ago in reply to icman
    Thanks so much guys I'll have a look at your suggestions.
