Power & Energy
Power & Energy
Forum LiFePO4 charging
  • Subscribers 283 subscribers
  • Views 730 views
  • lifepo4
  • battery
LiFePO4 charging
Given battery pack of http://www.a123systems.com/products-cells-26650-cylindrical-cell.htm in 3s configuration, can it be charged in CC until 10.8 volts are reached and then topped off in CV mode? Is individual cell monitoring as imprtant with LiFePO4 as it is with "older" Li chemistries?
Any suggestions for IC to manage charging of such battery pack?
Can't really find much information on charging of this type of batteries, so far have only found that it is similar to other Li-something except for lower full charge voltage 3.6 as opposed to typical 4.1-4.2.
  • RWM
    0 RWM over 14 years ago
    here you have application note from TI:
    http://www.ti.com/lit/an/slua443/slua443.pdf
    Used IC:
    http://www.ti.com/product/bq24105
  • RWM
    Linear Technology has wide selection of ICs:
    http://parametric.linear.com/battery_management#!1806_LiFePO4!1069_Linear|Switching!chem_LiFePO4!vmax_!icharge_!bat_bat
    0 e14 Contributor over 14 years ago in reply to RWM
    Thanks, somehow these skipped me on my quest for solution.
