Power & Energy
Power & Energy
Forum Help with a fuse
  • Subscribers 284 subscribers
  • Views 1312 views
Help with a fuse
I need a fuse ceramic T5AH250VP and I really need it today.   I assume it's a 5amp 250volt.   Will any 5a 250v ceramic fuse work?   There are 2 of them in the switch housing of a german milling machine.
I'm a dental technician and I use this machine to mill crowns and bridges.  The machine runs on 120volt.   Naturally, the fuse blows on a long holiday weekend.
  • YT2095
    0 YT2095 over 14 years ago
    Yes any ceramic fuse at that rating will work if A) it will physically fit correctly, and B) the most critical is it a Slow-Blow or a fast-blow fuse?
    point B) is really important to get right.
    all the best, and Happy New Year!
    Just want to add that the T means it is a slow-blow fuse. If you have an F there that would mean it is a fast- blow fuse, and that you should not use.
  • Eavesdropper
    0 Eavesdropper over 14 years ago
    John,
    See ebay: http://www.ebay.com/itm/T5-0AH250VP-T5-0A-H-250VP-Replacement-Part-NEW-/170684318903?pt=LH_DefaultDomain_210&hash=item27bd9404b7
    Or go to http://www.allparts.co.kr/ and search for your part #, request a quote. I am sure they will want you to order thousands. But consider being a secondary source for this fuse. The ebay person did it.
    E
