Power & Energy
Power & Energy
Forum USB transformer to charge a 9 volt battery.
  • Subscribers 283 subscribers
  • Views 996 views
HI all, I am a hobbiest.  This power project is way to harnest the power of usb connectivity. I have a ad to dc transformer with a usb connector. I want to charge a 9 volt battery. I think I need a step up transformer in my device or would I be able to use an op amp Ic to change the output to 10 volts needed to charge the battery? How would I go about making it a smart charger to have it shut off thn the battery is full? Am I just deaming that a Usb transformer could charge a  9 volt. I know it could do AA or AAA with a 5 volt regulator. I think I need to use a varible voltage regulator.
    Hi Mark.
    Of course it will work. You need a DC-DC converter (like: Note1). So you get a 12V Voltage from USB. Now you can use different circuites for charging the batterie. My recommentation would be a circuit with DELTA-V-DETECTION. You'll find circuits online (f.e.: Note2).
    Please post the progress of your experiments.
    Note1: http://at.farnell.com/jsp/search/browse.jsp?N=203947+310032328+310186688&Ns=P_PRICE_FARNELL_AT%7C0&locale=de_AT&appliedparametrics=true&getResults=true&suppressRedirect=true&isRedirect=&originalQueryURL=/jsp/search/browse.jsp%3FN%3D203947%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Dde_AT%26divisionLocale%3Dde_AT%26catalogId%3D%26skipManufacturer%3Dfalse%26skipParametricAttributeId%3D%26prevNValues%3D203947
    Note2: http://oshonsoft.com/picchargerlcd.html
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Thank you so much.
    Does it work?
    Not yet I had to stop working on it cause I am looking for a job. sorry.
