Power & Energy
Power & Energy
Forum 120VAC to 5VDC
  • Replies 9 replies
  • Answers 2 answers
  • Subscribers 286 subscribers
  • Views 1843 views
  • 120vac
  • 5vdc
120VAC to 5VDC
How would I go about converting 120VAC to 5VDC?
  • gadget.iom
    0 gadget.iom over 12 years ago
    TXM 015-105 - TRACOPOWER - POWER SUPPLY, AC/DC, 15W, 5V, | Farnell UK
    0 e14 Contributor over 12 years ago in reply to gadget.iom
    Sorry, I should have been more clear.  I need to power an Arduino, so it would have to output about 200mA.  Also, I would like to have something cheaper.
  • gadget.iom
    0 gadget.iom over 12 years ago in reply to e14 Contributor
    Would you like to build something or just find a suitable power supply?
    A simple option may be to procure a 5v power supply from a mobile phone or other USB powered device and cut the plug off if necessary.
    I would like to "build something" into a custom PCB, so I don't really want to use a 5V power supply...  image  Any ideas? image
  • klong84
    0 klong84 over 12 years ago
    What is the current rating needed? Make simple rc dropper circuits as described: Cap dropper circuit example
    I understood you don't want a power supply but off the shelf switchers can readily deliver several amps for next to nothing, .ie $5.
    0 e14 Contributor over 12 years ago in reply to klong84
    I need about enough to power an Arduino Leonardo (~40mA).
  • vsluiter
    0 vsluiter over 12 years ago
    Hello Harrison,
    If you want to do some more design work (and get a more stable / power efficient solution than the cap dropper), or look how simple phone chargers work, take a look at the site of Power Integrations. They provide the switching IC's that do the conversion in -for example- phone chargers. This reference design might do what you want!
    Victor
  • bodgy
    0 bodgy over 12 years ago
    If you are a beginner and would like to build your own power supply, you should consider making an isolated power supply, from both a safety and not blowing up your Arduino accidently point of view.
    You would need to use a power supply that has a mains transformer  in it.  This would be pretty simple to make, but on th eother hand as has been mentioned you could buy a mains rated plug pack that has all the safety features built in.
    For a home made one, you need a fuse, 120 -> 9v transformer, a diode bridge or just two diodes (depends on the transformer you buy), a capacitor and a voltage regulator 7805 or similar. That will make a basic power supply.  The transformer needs to be rated at, at least 1.8VA .
    Circuits with actual parts and part numbers can be made if you wish. There are many websites with basic linear power supply circuits.
    Colin
    please have a look at the reference design
    Wide AC input AC/DC power supply for 3 phase E-meter (5V @ 0.2A) - PMP4303.2 - TI Tool Folder
    KR
    Vincenzo
