Power & Energy
Power & Energy
Forum Power Supply For a raspberry pi and screen
  • Subscribers 285 subscribers
  • Views 734 views
vinegreen
vinegreen over 11 years ago
I have a computer power supply, and the 12v runs a current of 16Amps. would this be suitable for a screen that requires 2.5 amps?
  • clem57
    0 clem57 over 11 years ago
    This would be well over current needed  and if the screen has no protection, this could be bad!
  • vinegreen
    0 vinegreen over 11 years ago in reply to clem57
    won't it just take what current it needs?
    0 mcb1 over 11 years ago in reply to vinegreen
    Yes it will.
    Any load will only draw as much current as it requires .....
    HOWEVER if there is a problem and you accidently short out something allowing massive currents to flow, then a low current supply is less likely to destroy thing (tracks, components)
    The safest method is to add a 2.5A fuse in series with the supply feeding your screen. (It may already have one fitted externally or internally)
    That way you have plenty of power, but it will be protected.
    Before you connect this, you may wish to have it checked.
    The capacitors tend to age (dry out due to heat), which results in unwanted ripple Understanding, Measuring, and Reducing Output Voltage Ripple - SIMPLE SWITCHERRegistered FAQ - SIMPLE SWITCHERRegistered - TI E2E Communit…
    It's a simple matter of sticking a load on and measuring the ac componet across the 12v (usually with an oscilloscope).
