Power & Energy
Power & Energy
Forum Teardown Photos: Corsair RMe Series RM750e ATX Power Supply
  • Replies 15 replies
  • Subscribers 280 subscribers
  • Views 19243 views
scottiebabe
scottiebabe over 2 years ago
According to https://cultists.network/140/psu-tier-list/ the RM750e is a
Tier A • High-end PSU
Is it the best PSU ever? I don't know... You can decide that for yourself.
I do like the general layout and design to envelope. They made a great use of available volume with daughter cards everywhere!
The first EMI filter stage is nestled underneath the input IEC connector on a littler carrier card.
Cybenetics has a component breakdown list: https://www.cybenetics.com/d/cybenetics_9Nq.pdf
  • Gough Lui
    Gough Lui over 2 years ago +3
    Did you void the warranty already? Looks pretty good - the only thing I slightly dislike is the "cheapo" Teapo caps - they're not top tier, but they're not horrible. I just have a preference for all top…
    DAB over 2 years ago +3
    The best PSU ever is one that does what you need and works reliably.
    dougw over 2 years ago in reply to DAB +3
    I have only ever blown one PC power supply. Considering how many PCs I have used (dozens - I still have half a dozen that are operational) and the fact that PC power supplies are by far the cheapest supplies…
    I have only ever blown one PC power supply. Considering how many PCs I have used (dozens - I still have half a dozen that are operational) and the fact that PC power supplies are by far the cheapest supplies you can buy for amount of power they supply, I would say even the cheap ones have a great track record.
  • scottiebabe
    scottiebabe over 2 years ago in reply to dougw
    Still works...
    With the classic voltage selection switch
  • Gough Lui
    Gough Lui over 2 years ago in reply to scottiebabe
    CWT = Channel Well Technology - not a bad OEM.
    That being said, I've had more than a handful of dead PSUs ... but then again, I did probably handle hundreds of computers this lifetime. Some of them can be blamed on the early 2000's influx of cheap cases with integrated PSUs with counterfeit/bad capacitors and even branded PSUs with bad capacitors (I've repaired a number of Antec TruePower/SmartPower series PSUs of the era).
    Before then, it would normally be poorer-quality low-end PSUs from unknown OEMs that would fail, often rather explosively, sometimes due to a lack of proper protection when a mishap might have occurred during an upgrade (e.g. shorted output). Thankfully, I am yet to have a failure that took down equipment downstream.
    - Gough
  • me_Cris
    me_Cris over 2 years ago
    ClapClapClap
    DAB over 2 years ago in reply to dougw
    When I had my latest machine put together, they used an 850 W PSU.
    I think my old Commodore PET used about 150 W of power.
