Power & Energy
Power & Energy
Forum RF Noise - Do you notice the RF noise floor has greatly increased with the influx of wall warts?
  • Replies 24 replies
  • Subscribers 289 subscribers
  • Views 4013 views
Cquk
Cquk over 2 years ago
I would be interested to see if any one else has noticed the issue. Maybe if you work on RF devices / have a spectrum analyiser etc.
Even some bench PSU's seem to produce more EMI than i would expect.
I am working on adding Ferrite's to all my cables but where does it stop?
  • Cquk
    Cquk over 2 years ago +2
    Hi All Update I have found a tool to Identify the source of the noise: https://www.sdr-kits.net/index.php?route=web/pages&page_id=113_113 I will report back once I build it.
    DAB over 2 years ago +1
    They are built cheap, not as a quality power product.
  • dang74
    dang74 over 2 years ago +1
    I suspect that a noisy supply would manifest itself in the form of amplitude modulation which could raise the noise near any RF tones you're creating. It also wouldn't surprise me if you're seeing side…
  • Cquk
    Cquk over 2 years ago in reply to strb
    Do you have any info on the seminar sounds interesting ? This is just what I am trying to track down. Right now it’s everywhere.
  • bidrohini
    bidrohini over 2 years ago
    You can Add decoupling capacitors and proper filtering at the power input stages of your RF devices. It can help block noise from entering sensitive circuits.
  • strb
    strb over 2 years ago in reply to Cquk
    I don't have particular informations on your specific problem but yes, the seminar was very interesting. Basically anything that has inside a switching converter, if badly designed, could lead to added noise (conducted and/or radiated). Probably phone chargers and led lamps are the major issue as they tend to be on the cheap side.
    Have you tried to switch "all off" and then on one thing at time to see how the noise level changes? Maybe you can identify one or two major offender if you're lucky.
    DAB over 2 years ago in reply to Cquk
    Yes, in the old days, you could buy quality power supplies that were very steady and produced very few artifacts.
    Sadly those days are gone as we have mostly inexpensive devices that just barely suffice.
  • vmate
    vmate over 2 years ago in reply to bidrohini
    It's not really the power input to RF devices that's the issue, it's RF noise coupling into circuits from different devices.
  • battlecoder
    battlecoder over 2 years ago
    I've noticed this too. Since I got interested in EMI and RF I've been replacing low quality wall warts and adapters that I've noticed that are particularly noisy. Some of them are one mixer away from being actual radio transmission devices.
  • Cquk
    Cquk over 2 years ago in reply to battlecoder
    100% do you have any pictures of the ones you have found to be really bad. I just purchased a test tool to Identify these. I will report back as to how well it works.
  • battlecoder
    battlecoder over 2 years ago in reply to Cquk
    I might have a couple in a box. Will check and take pictures if I find them.
  • Cquk
    Hi All
  • beacon_dave
    beacon_dave over 2 years ago in reply to Cquk
    The Tapir E-smog detector may be of interest.
    Tapir - Ultrasensitive wideband magnetic/electromagnetic field detector
    https://www.elektormagazine.com/labs/tapir-ultraensitive-wideband-magneticelectromagnetic-field-detector
    TAPIR – E-smog detector
    https://www.youtube.com/watch?v=M-q37LKKzrI
