Power & Energy
Power & Energy
Forum RF Noise - Do you notice the RF noise floor has greatly increased with the influx of wall warts?
  • Replies 24 replies
  • Subscribers 289 subscribers
  • Views 4018 views
Cquk
Cquk over 2 years ago
I would be interested to see if any one else has noticed the issue. Maybe if you work on RF devices / have a spectrum analyiser etc.
Even some bench PSU's seem to produce more EMI than i would expect.
I am working on adding Ferrite's to all my cables but where does it stop?
  • Cquk
    Cquk over 2 years ago +2
    Hi All Update I have found a tool to Identify the source of the noise: https://www.sdr-kits.net/index.php?route=web/pages&page_id=113_113 I will report back once I build it.
    DAB over 2 years ago +1
    They are built cheap, not as a quality power product.
  • dang74
    dang74 over 2 years ago +1
    I suspect that a noisy supply would manifest itself in the form of amplitude modulation which could raise the noise near any RF tones you're creating. It also wouldn't surprise me if you're seeing side…
  • anniel747
    anniel747 over 2 years ago in reply to beacon_dave
    EMF-380 and EMF-390 are quite good to track down and identify sources.
  • Richtech
    Richtech over 2 years ago
    You may find that powerline network equipment from you or your neighbours has a large part to play. Those devices (and some are worse than others) put a comb of very wide band RF onto the mains which is detectable a long way from the source.
  • electronicbiker
    electronicbiker over 2 years ago in reply to strb
    You need a pocket spectrum analyser, or maybe a GDO? My eldest son bought a pocket oscilloscope, it does all sorts of things, maybe analysing spectrums is one of them. Four traces, each in different colours, all the probes, and an external timebase input.
  • electronicbiker
    electronicbiker over 2 years ago in reply to Richtech
    So-called 'smart motorways' interfere with my sat-nav, and arcade games send my car radio into a frenzy when I drive past some pubs.
