Power & Energy
Power & Energy
Forum Question electrolytic capacitor
  • Subscribers 281 subscribers
  • Views 1214 views
  • electrolytic capacitor
cloudff7
cloudff7 over 1 year ago
Manufacturers of aluminum electrolytic capacitors in storage recommend energizing these components once every 1 or 2 years and the temperature range is 5-35C and humidity is below 75C. After this interval, under these maximum conditions, they recommend refurbishing.
Do these recommendations only work on new aluminum electrolytic capacitors with little or no use because their chemistry is new and unchanged, or does this recommendation also work on old aluminum electrolytic capacitors that are used and assembled in electronic circuits and manufactured in the early 1990s?
    michaelkellett over 1 year ago +1
    Some people replace all the Al capacitors in old test gear as the first step in refurbishing. Others (me included) are more optimistic and only replace ones that have failed or look suspect. The life…
    Jan Cumps over 1 year ago in reply to michaelkellett +1
    michaelkellett said: Others (me included) are more optimistic and only replace ones that have failed or look suspect. I repair a decent amount of 70's and later gear, and I do the same. Replace if something…
    0 michaelkellett over 1 year ago
    The life of capacitors depends very much on temperature, voltage and ripple current.
    I've not measured and degradation in new unused electrolytic capacitors  even when they are 20 years old.
    0 Jan Cumps over 1 year ago in reply to michaelkellett
    I repair a decent amount of 70's and later gear, and I do the same. Replace if something fails, or a cap is obviously iffy.
    exception: Philips audio and test gear with switch mode power supplies of the 80's and early 90s. Their blue bulky electrolytes in the supply are done.
