Robotics
Robotics
Blog Assembling Marty
  • Author Author: rancell
  • Date Created: 29 Dec 2018 2:44 AM Date Created
  • Views 3372 views
  • Likes 16 likes
  • Comments 8 comments
  • robotics
  • marty
  • stem projects
Assembling Marty
rancell
rancell
29 Dec 2018
The other month I received a "Marty the Robot" kit in the mail from Element 14 for me to write some projects for (provided at no charge). I've done some previous posts here about using the micro:bit in education and am interested in seeing how this product would fit into that.
There's lots of parts in the box but the most interesting one I thought was the screwdriver! Which is great because you don't have to hunt around for exactly the right size and shape tool to use. This is a smart move by the manufacturer Robotical as this probably means a reliably good user experience in assembly for what is ultimately a pretty cheap part. Other manufacturers - take note!
Assembly mostly involved a lot of bolting parts together following the high quality provided instructions. The parts felt very sturdy and were reasonably easy to fit together though there were a few steps I had to check closely. The whole robot feels well designed for both assembly and ruggedness.
After assembling the legs I'm glad the instructions included the step below. I had indeed assembled them backwards and had to undo the bolts and reassemble. The silver lining is this did confirm that Marty is quite easy to rebuild.
The last steps involve you connecting up Marty's brain which is called "Rick". This board has both I2C and UART pins which means as well as controlling Marty remotely via WiFi you can also put in a micro:bit/Arduino/Raspberry Pi to control it directly. It also has a number of GPIO for adding additional sensors. Note the box does include cable ties so you can make it look less messy than the photo below.
Here is Marty fully assembled, he looks a little bit shocked! Total assembly time was around 2 hours.
The final step was to get Marty to connect to my WiFi network and calibrate the motors. This required installing an app onto my Android phone, connecting to a WiFi network Marty had created and entering my local WiFi details. Once that was complete, you can control Marty from the phone app.
    jw0752 over 7 years ago +6
    Hi Robert, Thanks for your post about Marty, I echo Rod that it would be cool to see him in action. John
  • 14rhb
    14rhb over 7 years ago +5
    Hi Robert, It looks like a great kit - you mention the quality is good and I can see that from the parts; neatly bagged up etc and the colourful instruction booklet. I'd be interested to see a video of…
    DAB over 7 years ago +3
    It looks like a cool kit. DAB
  • 14rhb
    Hi Robert,
    I'd be interested to see a video of Marty in action, what movements he can perform (ie where the servos are located), what is achievable from that app, what power supply does he need?
    Rod
    • Vote Up +5 Vote Down
  • laurence.molloy
    laurence.molloy over 7 years ago in reply to 14rhb
    Hi,
    I'm one of the original V1.0 Kickstarter pledgers from way-back. FWIW, I built my Marty with the help of my then 7 & 9 year olds.
    For those asking to see Marty in action, here's the promotional video from the Kickstarter campaign:
    https://www.youtube.com/watch?v=-w2JIjG_cXg
    And here's a cool hack  that the makers posted up a while back (alas, no instructions for this one yet... but who knows)
    https://www.youtube.com/watch?v=fWL90Y8XDKo
    Disclaimer: I'm not employed by Robotical but I do know the inventor. He was kind enough to give a talk and demo Marty at my primary school @codeclub.
    Laurence
  • laurence.molloy
    Hi,
    Laurence
