Robotics
Robotics
Blog Drones Gaining Widespread Use in Global Agriculture Sector
  • Date Created: 28 Mar 2016 8:10 PM Date Created
  • Views 987 views
  • crop
  • japan
  • law
  • drone
  • farming
  • crop_circles
28 Mar 2016
A crop dusting drone. (via agweb.com)
Notorious for its strict regulation around unmanned aerial vehicles, Japan is now opening up remote regions to special drone use zones. The areas of interest - efficacy of drones in monitoring crops, wildlife habitats, and delivering packaged goods to otherwise inaccessible regions within the country. Where exactly? Aogashima province, an island created by periodic volcanic eruptions, the mountainous regions around Hinahara, and the remote village of Okutama, which as recently as two years ago was blocked to thru traffic due to heavy snowfall.
While use of drones for data-gathering and performing simple tasks has spread to various industries, agriculture has seen an increased use of drones for a variety of jobs, crop dusting in the U.S. most recently. In Hinohara, it is hoped that sound-emitting drones will scare away monkeys, who feed on produce and dramatically reduce harvests. In other parts of the world, drones are used to scare away wildlife from damaging domestic food production as well; Canadian berry farmers have been testing drones to see if they are more effective as flying scarecrows than the cannons used currently to detract birds. In Sri Lanka, the International Water Management Institute monitored water stress in grain crops through the drones’ infrared sensors. Infrared sensing can detect molecular changes due to water, fertilizer or sunlight stress at levels far below the human eye, so stressed plants can be treated much sooner than they would be without the surveillance. While the use of drones for crop monitoring has increased, there’s a learning curve in the processing and application of that data.
Want to know what a crop circle looks like? Investigators in Russia recently used drones to get an aerial view of a large indentation in a wheatfield.  If you want to know if an alien spaceship made that crop circle, though, it may help to get a closer view. A large vessel moving at high speeds would produce enough heat and pressure that it would cause seed heads to burst. To my knowledge of the unexplained... I can not recall a single crop circle of any type in Japan.
Have a story tip? Message me at:
    DAB over 10 years ago in reply to Catwell
    I could see a very neat arrangement using the Google package dropping drones working with the overhead measurement drones taking robots to affected areas in a field to destroy fungus infections or to provide spot fertilizer applications all controlled by an integrated computer system with a little AI.
    You could also use a large number of tanker drones carrying retardant to fires.  IR sensors would let them drop the extinguishing agents at the critical spots of a fire.
    Lot's of interesting capabilities here.
  • Catwell
    Catwell over 10 years ago in reply to DAB
    I am sure we will see more of this too. Teams of drones tending to the fields. Swarm if you will.
    C
    I think agriculture is one area where Drones have a tremendous potential.
    It takes a lot of time for a farmer to look over each field and spot subtle changes in plant health before they become a large problem.
    A drone can automatically fly a prescribed route over all of the fields using a multispectral sensor, which could quickly spot changes and alert the farmer for insecticide or fertilizer issues.
    These larger drones have a lot of potential to save farmers a lot of money and time.
