Robotics
Robotics
Blog Kikousya replaces plastic and metal with paper for MPM robot design
  • Date Created: 30 Aug 2012 6:19 PM Date Created
  • Views 570 views
  • research
  • industrial
  • japan
  • autonomous
  • hmi
  • robotics
  • robots
  • control
  • robot
  • wind_up
  • toy
  • automation
  • navigation
30 Aug 2012
People have been making do-it-yourself robots for quite a while now, but they usually consist of metal and plastic of some kind and most require circuit boards along with in-depth programming to get them to function. Apparently that’s no longer the case, as Japanese paper-modeler Kikousya has taken paper-craft to a whole new level with his Mechanical Paper Model robots.
Kikousya designed the PR-III (Paper Robot 3 pictured above) using pieces of folded paper (looks as though he used CAD software to plot-out the pieces dimensions) to use as the robots frame and intricate gears/cogs along with a few wooden shafts which serve to increase the bot’s overall structural integrity. A few extra wooden dowels and paper gears make up the robots ‘engine’ (one crank attached to a two-stage gear) which uses wound rubber-bands to drive the robot’s feet.
Actually, the robot works like the wind-up toys from back in the 70’s and 80’s. Except instead of plastic, it uses wooden and paper cranks to engage the robots engine. Like any robot, it does have its weaknesses — water, fire and falling heavy objects, but it is impressive to say the least. Those interested in making their own Mechanical Paper Model robot can purchase the plans from Kikousya’s website (http://www.geocities.jp/kikousya290821/menue.htm), but be warned its in Japanese and a little tricky to navigate.
Cabe
http://twitter.com/Cabe_e14
