Robotics
Robotics
Blog Soft robot moves via chemical reactions
  • Author Author: Eavesdropper
  • Date Created: 17 Nov 2011 8:37 PM Date Created
  • Views 962 views
  • research
  • autonomous
  • hmi
  • robotics
  • robots
  • control
  • robot
  • on_campus
  • eavesdropper
  • university
  • automation
  • navigation
Eavesdropper
Eavesdropper
17 Nov 2011
Scientists at MIT’s Chembots program have just introduced a self-contained,  self-propelling  robot.  The gimmick of this bot is to house its power cell and locomotion mechanism all in it structural housing.   This automaton, or self-operating  machine or mechanism, is made up of silicone bladders and moves with the aid of a pneumatic battery.  This battery uses hydrogen peroxide catalyst reaction that helps maintain a stable pressure inside the robots on-board pressure vessel. The reaction inflates the soft silicone pod, in turn forcing the robot forward.  All it takes is a small current to go through built in valves, which are regulated with onboard electropermanent magnets.
How the battery works.
Valve cross-section.
Although the slow walk of this bot may not be enough to impress the projects funders, DARPA and Boeing, the valve system might be. The main focus in the experiment was to create flexible, and controllable, movement.
Read more about the technology in the group's paper, "Soft Robot Actuators using Energy-Efficient Valves Controlled by Electropermanent Magnet."
Eavesdropper
    DAB over 14 years ago
    Another simple, elegant approach.  I like the possiblities this technology can be used in.  If you covered the device with solar cells, you could have a rolling robot that could cover a wide range of terrain.
    Neat.
  • Eavesdropper
    Eavesdropper over 14 years ago in reply to DAB
    It just needs to go much faster. Plus, knocking it on its side would take it out of commission. I would think a ball like squishy bot would be more ideal using this tech.
    E
  • Eavesdropper
    E
